[Fixed] Transform pick point
micro26
On 11/19/2020 at 1:31 AM, Carlosan said:
On v 4.9.66 is ok.
Well, I have a fresh installation of 4.9.66 (uninstalled 4.9.65) and the pop up window of transform tool is not like yours Carlosan!
It is still like the image Micro26 has attached. "Pick Pivot", "To Bound Center" and  "Align to View" options are missing.
Tested in both GL/DX versions, also I tried to reset settings but no luck.
Is there something I miss?
Thanks
Edited by geoath
I tried a new installation but no luck again (I even tried to delete all options related xml files).
One workaround I found, is to press shift key while dragging the transform gizmo which allows me to reposition the gizmo.
Should I report it as a bug to the support team?
Thanks
