Advanced Member micro26 Posted November 17, 2020 Advanced Member Report Share Posted November 17, 2020 Where did the Transform pick point option go missing in version 4.9.65. I picked the surface it moved the gizmo to my picked location. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 18, 2020 Report Share Posted November 18, 2020 On v 4.9.66 is ok. Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted November 19, 2020 Author Advanced Member Report Share Posted November 19, 2020 I am using the stable version 65 from website (link). Quote Link to comment Share on other sites More sharing options...
Member geoath Posted November 22, 2020 Member Report Share Posted November 22, 2020 (edited) On 11/19/2020 at 1:31 AM, Carlosan said: On v 4.9.66 is ok. Well, I have a fresh installation of 4.9.66 (uninstalled 4.9.65) and the pop up window of transform tool is not like yours Carlosan! It is still like the image Micro26 has attached. "Pick Pivot", "To Bound Center" and "Align to View" options are missing. Tested in both GL/DX versions, also I tried to reset settings but no luck. Is there something I miss? Thanks Edited November 22, 2020 by geoath Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 22, 2020 Report Share Posted November 22, 2020 <---- out of ideas, sorry. Delete options.xml ? //edit fixed on latest versions Quote Link to comment Share on other sites More sharing options...
Member geoath Posted November 22, 2020 Member Report Share Posted November 22, 2020 Unfortunately It didn't work I'll try to uninstall and install and let you know.. Quote Link to comment Share on other sites More sharing options...
Member geoath Posted November 22, 2020 Member Report Share Posted November 22, 2020 I tried a new installation but no luck again (I even tried to delete all options related xml files). One workaround I found, is to press shift key while dragging the transform gizmo which allows me to reposition the gizmo. Should I report it as a bug to the support team? Thanks Quote Link to comment Share on other sites More sharing options...
