Kuro's 3D Art 0 Report post Posted November 17, 2020 Im using 3Dcoat for Retopo and UV. I do my models in zbrush (go through the pipeline, decimation etc) then import them in 3dcoat and i can do the retopo. The issue is with the retopo exported OBJ, everytime i try to import them back to Zbrush a message appears "Error encountered while importing a file". I tried different models and subtools, and it always gives me that error. One time it did allowed me to import a mesh but it was deformed even though it looked fine in the retopo room. I tried to import that "deformed" mesh into 3dcoat to see if the issue was Zbrush, but it look deformed in 3dcoat too, so my guess is that the issue is 3dcoat only. Also tried using fbx but it was pointless. Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted November 17, 2020 Hello Use the command remove nGons if any. Turn mirror mode off Triangulate at export options Hope any of this steps help. Share this post Link to post Share on other sites
pickers 24 Report post Posted November 18, 2020 The problem is with zbrush. you need to flip the texture or something. Share this post Link to post Share on other sites
Kuro's 3D Art 0 Report post Posted November 18, 2020 9 hours ago, Carlosan said: Hello Use the command remove nGons if any. Turn mirror mode off Triangulate at export options Hope any of this steps help. I tried it but it didnt work. Share this post Link to post Share on other sites
Kuro's 3D Art 0 Report post Posted November 18, 2020 4 hours ago, pickers said: The problem is with zbrush. you need to flip the texture or something. I think the issue is 3dcoat, i tried importing the same retopo objects i exported from and to 3dcoat and the meshes were empty or deformed Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted November 18, 2020 Can you share the project to take a look ? Share this post Link to post Share on other sites
Kuro's 3D Art 0 Report post Posted November 19, 2020 On 11/18/2020 at 12:23 AM, Carlosan said: Can you share the project to take a look ? The issue sadly is with any object. I tried using other meshes like primitives from zbrush, and once i export the retopo mesh with 3dcoat the error message appears on import in zbrush and a blank mesh on 3dcoat. Share this post Link to post Share on other sites
sprayer 38 Report post Posted November 19, 2020 Are you using latest version of 3dcoat? Share this post Link to post Share on other sites
Kuro's 3D Art 0 Report post Posted November 19, 2020 13 minutes ago, sprayer said: Are you using latest version of 3dcoat? I am, I also tried unistalling and reinstalling. Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted November 19, 2020 Follow this steps please Hope it help Share this post Link to post Share on other sites
