RetopoBro
[Bug] Paint room issue
Hi,
I've been having issues in the paint room so I imported the default cube from blender and noticed strange lines showing up on faces.
First Image
I tested the default cube on older version of Coat ver. 4.8.44 and the issue is not there.
Any help would be great, tested DX and GL version same issue.
Thanks
UVmap is OK?, it look as a seam.
Hi Carlosan,
I took some other screens which show the UV's and have better background contrast. It's not a seam as I am only painting across a face and not crossing seams.
A simple way to test is just send the default blender cube over to coat and paint across a single face.
Its happening on the normal map as well.
but default blender cube dont have UVs
could you please share that cube model
I found the same error I do not know what causes it, I advise using older versions to check if the problem persists.
I am reporting it as a bug.
Thx for point it up.
