Advanced Member DustyShinigami Posted February 5, 2021 Advanced Member Report Share Posted February 5, 2021 (edited) Hi Are there any other tips or tricks someone could share to help get the geometry to sit better on a mesh when retopologising? At the moment, a lot of my retop work seems to sit through the mesh. This piece shows what I mean: None of the faces/points are connected to any through the high-poly on the other side (that is a mistake I have been making though). I don't have the inside retopped. And I keep trying to use Relax and Snap, but if anything, Relax just makes it worse. When I've used Maya for retopping, the retop tends to sit more snuggly to the high-poly. And the relax tool, when pressing Shift, does a much better job. You can also adjust the offset in Max and Maya. Can you do the same thing in 3DCoat? Usually adding extra edge loops can improve the retop and make it conform to the high-poly's shape/silhouette, but often I find that doing that doesn't make any difference - it still gets buried within the mesh. :-\ Thanks Edited February 5, 2021 by DustyShinigami Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 5, 2021 Report Share Posted February 5, 2021 Hi Autosnap is turned on ? Additional Extrusion and z-bias could help too. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member DustyShinigami Posted February 5, 2021 Author Advanced Member Report Share Posted February 5, 2021 Both of those have helped. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
