GMG3D 5 Report post Posted February 9 We are having issues trying to render turntables in the render room. Setting up the render to custom 1920 x 1080 - it resets back to 1920 x 1017. Is this a bug? Currently using 4.9.65 It would be better if the settings interface allowed you to setup the render format, and choose different outputs (tga, png, jpg, etc..) for the image sequence, then hit render from the setup window. Share this post Link to post Share on other sites
Carlosan 2,560 Report post Posted February 9 Hi Hope this help On 8/12/2017 at 12:27 PM, digman said: You do not need to use the render turnable under the help menu. You are forgetting to set " Render Frame Sequence" in the Render settings panel. I saw it was unchecked in your picture. Once you have everthing setup just click on "Render" and the sequence files will be saved. Be sure to select Store Alpha Channel and your images will be automatically saved as TGA files with the alpha channel. Also select save lossless images just to be safe. Custom size is for positioning of the area to be rendered if you choose to use custom size. The yellow box will appear once you start to adjusting the size of the box. Side Note: I was just choosing 200 rays per frame to render as I was testing, the default 1000 is fine. Of course choose the amount you need. 360 frames will give you a compete turntable circle. Esc does work. I created the folder "man" in the settings panel and it automatically saves the tga files under the My Documents / 3D-CoatV47 / RenderImages / man, at least for Windows 7. Shown in picture. 3DC anti-aliasing is so so when rendering a turnable but since it is a moving model should be ok but you will have to be the final judge of that. Share this post Link to post Share on other sites
GMG3D 5 Report post Posted February 9 I'm starting to realize the problem is that we are setting the view size expecting it to render at that size and it does not. To render out at 1920 x 1080 I'm assuming we have to use the 'create turntable' option only. Share this post Link to post Share on other sites
GMG3D 5 Report post Posted February 9 Maybe 1920 x 1080 isn't possible? It crashes when I try to render with post processing and set the format. I will update all my drivers again and try once more later, but so far, I can not render at 1920 x 1080 on my Alienware laptop. Share this post Link to post Share on other sites
Carlosan 2,560 Report post Posted February 9 You are right, is not working. Please remember to send Bug Report. Thanks 1 Share this post Link to post Share on other sites
GMG3D 5 Report post Posted February 11 Thank you, will send the reports. 1 Share this post Link to post Share on other sites
