Advanced Member Ratchet Posted February 15, 2021 Advanced Member Report Share Posted February 15, 2021 (edited) Mainly for sculpting , i thtink this will be the next step because a mouse or a graphic tablet are working on a XY plane only. Without needing VR heaset that is tiring, you could work on XYZ spatial axis, as fast as your movements can be without needing to drag a mouse or a pen on a surface. This saves lot of manipulation, allowing to work lot more faster, specially for concepting. It's weird, no one have been inspired by that to create such controllers for PC and adapt them to existing 3D sculpting software. This would be possible to work as fast and easy and fast without but without a headset Edited February 15, 2021 by Ratchet 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member nobackup Posted February 16, 2021 Advanced Member Report Share Posted February 16, 2021 you could try a spacemouse, but they are a bit pricey. Quote Link to comment Share on other sites More sharing options...
