[Solved] Paint along spline with spacing ?
Callak
So, I've been trying to use "Paint along spline" with the "with spacing" option turned on, spacing is set to %100, I've tried %150 and %200.   But when I hit enter, nothing happens.    If I turn off "With spacing" it works fine.  But for what I'm trying to do I need to adjust the spacing between brush dots, rather than create a stroke.  Is this a bug, or am I doing something incorrectly?
Hmm, maybe I don't understand how to use the with spacing properly, but I experimented with using "Paint along spline" with strips a little, and I think I can accomplish some of what I need that way for now.   I still think this might be a bug though, unless someone can show me what I'm doing wrong.
Hello
I am testing version 4.9.72 and cant find any issues.
Are you using latest version ?
2 hours ago, Carlosan said:
Hello
I'm using the latest version released from Steam:  4.9.60.
Tried to switch to beta for the Steam download and it gave me 4.0.0.3.  XD
Check this information please
Hope it help
I've had a problem finding that licence.dat file in the past.   I did download the latest version today but haven't installed it yet.   I'm a bit burnt out from my efforts today, so I'll try to get the latest version running Friday, my next day off from work, when I'm fresh.
Hope it help
Ok, here is the problem I'm having with this.....   the new install is using the same data folder as the steam version, which already has the licence.dat file in place.  I checked the "Relocate 3DCoat's data folder" option to make sure it was currently pointing there.  Yet the new version is still running in amature mode, when it should be in consumer mode.
Edited by Callak
Please contact sales@3dcoat.com to inquire about this issue.
Thanks
Ok, a couple of things.
First- In case anyone has this issue again, I'm going to mention it here.   I was informed by Oleg from the 3DCoat team that the "Consumer" Steam version, is the same as the "Amature" web download version.   The "Consumer" version on Steam is just a legacy thing I guess.   I tested the number of layers available in each, after I was informed, and indeed they are the same, in that respect.
Second- Ok, I finally have the latest version.   Tested it, Carlosan, looks like I have the same settings you do from what I can tell?  It still does not respond when I hit [enter], or [Apply].
1610364824_Screenshot2021-03-1907_54_33.thumb.png.30bd6eae6805622c673975c53f15544c.png
Edited by Callak
Sorry i am trying, but cant replicate this issue.
Try resetting 3DC default values
Hope it help
Interesting.....   that fixed it.
It's doing it again.   There has to be a bad array or memory leak causing this issue.   I do not wish to reset the settings every time I am ready to use paint along spline with spacing.   The only other setting change I made was to change the default external editor to Krita instead of Adobe Photoshop.640533348_Screenshot2021-03-2108_34_06.thumb.png.89b372c1109d020b5eae97d425d9d699.png
Edited by Callak
Never mind, I had a strip selected.
