Advanced Member Yousung Posted March 19, 2021 Advanced Member Report Share Posted March 19, 2021 (edited) SculptTree feels quite difficult and uncomfortable to manage. So, when the work is completed for each part, the sub-trees are temporarily grouped with Merge Sub-Tree (no boolean), and whenever modification is needed, the Object-ify (Separate) function is used to perform separation work. --------------------------------------------------------------------------------------------------------------------------------------------------- As the work continues, there is a part that needs to be cut out as a whole, so without using Object-ify (Separate) I used Cut Off Tool. The result is an object with an empty inside, such as an image (left-below). It was not the result I wanted, so after restoring it to its original state This time, after separating the parts with the Object-ify (Separate) function, I did the same work as before using Through All Volumes of Cut Off. This time, the results came out as i wnat it is. (right-below) It seemed to be the same, but the result was completely different. The question is... Is it a bug of the Cut Off tool? Or is it due to some mechanism of Merge Sub-Tree(no boolean)? Edited March 19, 2021 by Yousung Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 19, 2021 Report Share Posted March 19, 2021 Hi Are you using latest version ? I am testing v4.9.72 and split tool (surface mode) is working fine from my side. Quote Link to comment Share on other sites More sharing options...
Advanced Member Yousung Posted March 20, 2021 Author Advanced Member Report Share Posted March 20, 2021 Hi @Carlosan The version when I tested it was 4.9.67 (GL64, DX). As you said, I updated to version 4.9.72, but the problems were still there. Both Cut Off and Split show the same problems. attach files in hereTest_Merge (no booleans).zip Try to cut/divide through the overlapping area rather than a single object. It will appear as in the image 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 21, 2021 Report Share Posted March 21, 2021 You are right, is not working as expected. Send support-related questions requests at support@3dcoat.com Thanks Quote Link to comment Share on other sites More sharing options...
