Yousung
[Bug] When use the Cut Off Tool, the inside becomes an empty object.
SculptTree feels quite difficult and uncomfortable to manage.
So, when the work is completed for each part, the sub-trees are temporarily grouped with Merge Sub-Tree (no boolean), and whenever modification is needed, the Object-ify (Separate) function is used to perform separation work.
As the work continues, there is a part that needs to be cut out as a whole, so without using Object-ify (Separate)
I used Cut Off Tool.
The result is an object with an empty inside, such as an image (left-below).
It was not the result I wanted, so after restoring it to its original state
This time, after separating the parts with the Object-ify (Separate) function, I did the same work as before using Through All Volumes of Cut Off.
This time, the results came out as i wnat it is. (right-below)
It seemed to be the same, but the result was completely different.
The question is...
  1. Is it a bug of the Cut Off tool?
  2. Or is it due to some mechanism of Merge Sub-Tree(no boolean)?
Edited by Yousung
Hi
Are you using latest version ?
I am testing v4.9.72 and split tool (surface mode) is working fine from my side.
Hi @Carlosan
The version when I tested it was 4.9.67 (GL64, DX).
As you said, I updated to version 4.9.72, but the problems were still there.
Both Cut Off and Split show the same problems.
attach files in here
Test_Merge (no booleans).zip
Try to cut/divide through the overlapping area rather than a single object.
It will appear as in the image
You are right, is not working as expected.
Send support-related questions requests at
support@3dcoat.com
Thanks
