So I've been trying to unwrap a model and in the UV room the islands look just fine:
But if I go into the paint room it looks like this and the result also carries over to other 3D software:
Hi
Once you hit the "Apply UV-set button" then it's done, you dont have to do anything else, you will paint, see and use the new UVs.
3 minutes ago, Carlosan said:
Hi
I think you misunderstood, this is the result in the paint room after I clicked apply UV set.
Are yo using latest version 4.9.72 ?
Try this please
- Apply UVs on UV room
- Select the paint room
- A popup will ask to apply the UVs, select cancel
Try this please
I think so, I bought mine on Steam but I'm assuming that's being kept up to date.
But yeah that's exactly what I did, but for some reason some of my UV islands just end up being stretched into that corner.
I also managed to fix this in 3DS Max, but after exporting it and then trying to import it into 3D coat again the same thing happened, then I tried that same file into Substance painter and it was fine there.
In the end I noticed that on the back of my model in the UV room there were a few faces that didn't get the checkered pattern projected onto them, so I ended up removing them since nobody is gonna see that part of the model anyway and after that it worked. Still not sure what caused that though.
As i remember this error is possible if some faces dont have uvseams or are out of current UV space (U1-V1)
It did have seams around it, so it must have been somewhere outside of the UV space then. Thanks for your help.
