thats really strange .. mine should be able to get that easy then, might have to look into why its crashing ,i honestly cant even get 32 mil
Hi,
I got a crash using the latest version.
Surface mode, 1.2 mil tris, draw brush with some spacing and Auto subdivide turned on using that little pill brush.
Notice how it misses a draw every so often but still subdivides the surface, then it crashed when moving slowly in this circular motion.
Testing on a older laptop, Asus I7-4700HQ ROG GTX 780m 24 gig ram, Windows 7
2 hours ago, gnulinuxkernel said:
Which tablet you use? I have similar issues with painting on new Chinese tablet (VEikk), but my Wacom work fine
Using Wacom Intuos Pro, mapping is in Pen Mode.
2 hours ago, RetopoBro said:
Hi,
On Linux Lubuntu running in wine, I can sculpt on 46 million tris connected mesh at around 50-55fps with rapid brush (auto subdivide off). I feel I can go higher.  If auto subdivide turned on, the brush becomes VERY SLOW, but not crash.
Computer: intel i7 2600k, RTX 2060, 16GB ram.
Maybe a windows problem that causes crash?
Edited by animk
4 hours ago, RetopoBro said:
Hi,
This is likely happening because the default Subdivision value is about 10x too high. I have reported this to Andrew, but I don't think he has addressed it yet. The default value on my current system, does not cause a crash, but it stalls the application for several seconds or longer. One needs to change the default value to 10x lower. Instead of 2.0, it should be more like .2 or instead of 1.0, it should be .1
Some UV tools in the Modeling Room do not work.
- Mark Seams
- Edge Loops
UV Path works well
It works fine in Retopo Room.
On 4/8/2021 at 11:18 PM, Barrel said:
Unfortunately, I very often faced a variety of problems in the retopology room in all versions, so I most often do retopology in other programs.
In the end, it is not even possible to transfer an object normally from retopology to sculpting. The most normal way is to export the file in the retopology room and import it into the sculpt room.
This is heresy.
I got it working, after "modeling" room you need to use "retopo" room before "sculpting" room.
1) Once low poly is complete , switch to retopo room
  •     uncheck "Virtual mirror mode"
  •      check on "Apply symmetry to all layers"
3) Switch to "Sculpt" room, choose "Objects" -> "Import"
  •     uncheck "Respect Negative volumes"
  •     check on "Import so separate instance" and adjust "ExtraInstanceDensity" as you wish
There should be official video tutorial to show the process getting modeling to sculpting without issues.
Edited by Ratchet
  • Thanks 3
Hi,
I noticed when I click on the Retopo Shell button in the Retopo Room the mesh just disappears then reappears when I click a new button.
Tried it with faces selected first and without, same result.
10 hours ago, RetopoBro said:
Hi,
To be honest, I don't think Retopo Shell is even supposed to be in the application. It was a beta tool a developer who no longer is with Pilgway, was working on. Andrew has since created a SHELL tool that does this job. I think the developers forgot to remove this.
  • Haha 1
Poly modeling room This may have already been mentioned:
When clicking on the measure tool in the poly Modeling room the object disappears.
Object does not come back until you select another tool.
version 2021.B42 (GL64)
Steps to reproduce: create a primitive object
Click enter
Click on Measure tool
Edited by mash
addition
Poly modeling room Last tool selected is still selected when clicking  "New File"
Steps to reproduce: Open 3d coat
Go to poly modeling room
3d primitive tool is already selected  and object is in center of the grid
Click enter to create the primitive
select knife or any other tool
Click "File New" (Ctrl-N)
go to poly modeling room
Knife tool is still selected instead of 3d primitive as it is when you first start the program and enter the Modeling room
Poly modeling room : Standardization of tools
Cube primitive and some other primitives do not have sliding controls for Size
When uniform division is unchecked X, Y and Z divisions have a sliding scale < X >  where you just click and drag left and right to
adjust the input.
Size should have the same functionality  to keep tool usage and interface consistent.
Also Is it possible to have local versus World positioning for 3d primitives?
Edited by mash
addition
If this thread is a right place to submit new feature request based of 3d coat 2021 beta
I would like to ask:
Projector tool in the sculpt room
It would be very helpful if we could import cameras from 3th party softwares in abc, fbx, cam, etc.. file format. and use it as a projector.
In my workflow in VFX we very often have a plate images with specific FOV ( specyfied sensor size and focal length in mm) and we would like  to be able to model
in a 3d coat with projection from that specific camera angle in 3d space.
Is it possible to submit this feature request and how I would be able to know if it was approved or denied ?
Edited by MariuszKolo
Sure, please send any feature requests at
support@3dcoat.com
Thanks
Hello,
New to the forum and was quite excited to test out the low poly feature coming to 2021. It may not be a big deal for other people and I know it is still being worked on. But I have been playing with the Extrude and the Spine Tool. I have hit every button to see if instead of having to hit the 'New Extrude' button I could get an extrude and didn't see that it was possible. Wouldn't it be more effective if the person could just hold the Ctrl button while clicking and pulling the end point to make a new extrude? I think it would add to the speed of modeling. But just throwing out a thought.
On 4/10/2021 at 7:38 AM, Scary M said:
If it helps ive been looking at the amount it offsets and it seem relative to the cursors position on the screen, The UI scales funny even more so in fullscreen is 3d coat running at some locked internal resolution or weird scaling? Like Half the resolution of my 4k monitor??
Thanks for this clue.  After testing, I think it's affected by Windows UI scaling.  I've confirmed that I can get Wintab to work properly on my 4K monitor if I set the UI Scaling to 100% in the Windows Display settings.  When I had mine set to 200% it scaled the brush location from my cursor by 200% from the top left corner, causing the offset.
@Andrew Shpagin hopefully this makes it easier to fix if you are still tracking this issue down.
Edited by gbball
Instead of having to hit the 'New Extrude' button you could press Enter
Does anyone know how to use the Cross Section of the Loft Surface tool in Modeling-Room?
Even if I test it around, I'm not sure what this is or how it works.....
If i move it after adding a curve to the cross section, only the polygons are twisted and destroyed... :(
If we click 'Snap to Low Poly Vertices' is it possible to get that to translate into all tools (brush won't snap to vertices when placing 3D primitives with 'Click to Place enabled)
Also getting bizarre ghosted viewport geometry appearing while using the 'Cut' tool, which obscures the model
- Rich
Edited by -rb-
Are the Linux and OSX builds coming soonish or are those builds expected not before some weeks or months yet?
I don't particularly mind to wait, but I could skip keeping track of threads like this until we get them. It surely looks promising this new 3DCoat.
Thanks in advance for any estimation given. :-)
