3DCoat 2021 Open Beta test !
On 7/14/2021 at 3:04 PM, linnos said:
@SERGYII recorded a video of the issue attached to this comment if that helps. I'm running PopOS Cosmic which is based off of the latest ubuntu 21.04 I believe. AMD GPU and CPU.
2021-07-14 07-55-35.mkv
On my Ubuntu 20.04 with CPU i7 and GPU AMD Radeon Pro 555 the "Bake w/ Normal Map" works (no crash). I have tried to install Ubuntu 21.04 but it doesn't start after installation.
It has to be an issue with Ubuntu 21.04 then. What are the next steps to try and fixing the problem if you can't install 21.04?
Because of the new LLVM I would like to install Ubuntu 21.04 regardless since it doesn't start after installation on my machine. But it will take some time to understand how to do that.
I had an issue after installing 21.04 where I could log in, but it would be a black screen. Reddit was able to figure out what that solution to that problem. Is your issue similar?
Hello, in the new Coat strokes feels very strange, take a look at this screenshot, and here my hand move was pretty slow and smooth.
On 7/14/2021 at 8:47 PM, Andrew Shpagin said:
Huge thanks to everyone for participation! I started the thread dedicated to 2021 development. I posted the newest build there.
https://3dcoat.com/forum/index.php?/topic/25785-3dcoat-2021-development-thread/
Thank you for this awesome software!
No. Just black screen after EFI. No errors from GRUB. Google finds other users with the same problem after installing 21.04.
  • 1 month later...
