3DCoat 2021 Open Beta test !
8 hours ago, Elemeno said:
select should use a replace each selection... so when you select a face or edge and then select another edge it will remove the previous selection and only way to stack selection woul be using the shift key,
You can clear your selection quickly by pressing Ctrl+D.
I personally find the 'Shift-less' selection method as much more intuitive and faster than, say, Blender's.
Also, once you ascribe shortcuts to Low-Poly and Sculpting rooms, switching between polygon edition and sculpting mode (with the 'Sculpt Mesh' link between Low-Poly and Sculpt room) feels much easier than in Blender, where you have to call a pie menu etc. etc. To each their own, I guess.
All of these advantages (imo) seem defeated - for the time being - by sheer instability of both the Low-Poly workflow and the link to Sculpt room.
Breaking links, Pose tool not working, awkward behaviour of so many tools available.
I'll keep my fingers crossed and stick to Blender / PolyQuilt for now for a combo of polygonal editing and quick sculptural tweaks.
Posted (edited)
3 hours ago, sprayer said:
 it's freezing for me, looks like because too many points, simplify curve also freeze or to long for operation.
Yes it takes several minutes for simplify, but it works strange
The problem was the silhouette too close to the border of the image, i just made the canvas bigger and it's work so this is not a bug.
EDIT: It is very unreliable in 2021 since the result is not working consistently here an example :
Edited by polynut
  • Thanks 2
Andrew, Apologies for bringing this up here. I bought the V4 to 3DCoat permanent upgrade. Haven’t received the license keys, Also the invoice or license is not showing in my account either. I wrote to the ID mentioned in the invoice. Any help would be appreciated.
Thomas, you might be able to get a faster response by emailing sales@3dcoat.com and asking for assistance. I will send a message  so they know to be looking for your email/license
Thank you AbnRanger. Much appreciated
On 7/10/2021 at 4:33 PM, ebitz said:
Concerning "construct new Shader". Specifically when trying to construct a new shader from one of the two existing default matcaps, after naming, the screen will freeze but not crash. Simply adjusting the window around in the monitor unfreezes it. However 3d coat will enter you into the PBR parameters rather than the Matcap dialog. If you cancel the operation at this point the new matcap shader is created anyway. From there you can edit the shader settings and the matcap dialog will appear as expected. Simply put the matcap dialog for "construct new shader" is replaced initially with the PBR dialog instead.
Another issue is that once a new  matcap is created from one of the existing default ones, there is a file that fails to be generated into that new shaders userprefs folder. This missing file is the " CustomSampler3.dds". I have found significant viewport performance when this file is present. Now, once you construct new shaders from the new user shaders the file comes along and things work as they should. I have no idea why this "CustomSampler3.dds" file increases my performance or why it is relevant.
This error is also present in 4.9.75
On Linux Ubuntu 21.04 Based.
I have discovered what the CustomSampler3.dds does for  a user created matcap shader. This specific .dds file allows you to see your pose tool gradient colors. If you have created a new matcap and do not see the gradient colors from the pose tool in your scene just copy the "CustomSampler3.dds" file to your user matcap created file in your Documents folder directory.
12.07.21 3DCoat-2021.01
- Reassigning shaders fixed.
- "View->Show separate axis" works correctly.
- If the scene has nodes attached the baking dialog will remind to bake nodes first.
- "Bake->Bake w/ Per Pixel Painting w/ Displacement" bakes the color from layers and shader correctly.
- Nodes baking into scene correct.
- a lot of small polishing, a lot of icons updated.
so 130 euros to upgrade to 2021 which personally doesn't seem like a worth while upgrade... why so expensive when 4.9 has more or less all the same features....
i mean ive had V4 for a couple of years now and in that time ive had voxels breaking and lose work... and 2021 still has this so whats the point of the upgrade.
i mean it clearly has upgrades and new features, that theyve made vids of, new UI aside. but you don't have to use it, if its not worth it to you then don't, I guess, tbh
they have removed 4.9 download availability....
why would they do that
also how can they charge so much for something with still so many bugs in the voxel system , i can guarantee my sculpt mesh will have some weird artefacts every time I use 3dc.
hopefully throughout the year they add some amazing stuff but zbrush seems like a more likely choice now and its lifetime upgrades too..
I use both and they both have uses that the other cant or doesn't do as well, so it's not an either/or thing imo, I will say that this has a lot less bugs than I've been used to experiencing on older installs and it's more responsive than ever, before you even get to new features so it was a no-brainer upgrade for me in my work.
  • New Member
19 minutes ago, Hdharris said:
is anyone else getting an integrity error when you try to install?
As per Hdharris also getting integrity error when trying to install 3Dcoat-2021-01.  Any fix?
Cheers
If you receive NSIS error Windows 10 while installing a program, it is very likely that the installation files are corrupted or incomplete.
Try this link please
//edit
4 hours ago, Andrew Shpagin said:
Thanks for reporting, fixed it on the main site too. Seems there was a problem with Google mirror... The size is normal, it was optimized, it is more lightweight.
3 minutes ago, Carlosan said:
@Elemeno Upgrade to permanent is € 75 + VAT
75+vat may not seem a lot but when you've got mortgage ,bills ,car, kids ,wife it adds
don't try to belittle people .
  • New Member
Carlosan you've linked a MACOS file for a windows installation
