Reputable Contributor AbnRanger Posted April 9, 2021 Reputable Contributor Share Posted April 9, 2021 8 hours ago, pattanner said: Also issue with opacity settings in paint room, with light pressure on wacom pen, initial contact for stroke still begins at 100% opacity. I reported this problem a week ago, so it is confirmed. I hope Andrew fixes this ASAP, as it makes painting a royal PITA Link to comment Share on other sites More sharing options...
Advanced Member Yousung Posted April 9, 2021 Advanced Member Share Posted April 9, 2021 Test in 2021 (B40) This is a curve option that appears in the Modeling Room. I only thought about the RMB menu, but I forgot that there was also something like this at the top.... Anyway It seems to be a function that fills the inside of the curve area with a quad or triangle face. Doesn't work. In the case of Triangle, it crashes. Do i need specific conditions? Or is it a bug? Link to comment Share on other sites More sharing options...
carrots Posted April 9, 2021 Share Posted April 9, 2021 On 4/5/2021 at 2:29 PM, artofcharly said: Hi, dear developers. I noticed a strange issue with Renderman. Tried to render a simple head and the 3D-Coat was Freezed. Installed the latest version. Video with an issue -> Steps: - Open 3dcoat - Select voxel 3d head - Go to RenderRoom - Select Renderman - Click Render Preview How to fix this? Thank you and have a great day Best regards, Andrew. Fixed, in the next build will work 2 Link to comment Share on other sites More sharing options...
Member Frimasson Posted April 9, 2021 Member Share Posted April 9, 2021 2 cents : The new super relax brush is FANTASTIC to clean rough scans You should add a " super relax whole model" in one click tool 2 1 Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 9, 2021 Author Share Posted April 9, 2021 9.04.21 B42: - Voxel brushes updated, voxel brush engine introduces, similar to surface brush engine. Pay attention, VoxelEngine is subject to change, so we can't guarantee your presets related to the voxel engine will be preserved. Anyway, it is faster, more flexible. And very good point it offers real clay-like brushes for voxels. - A lot, lot of bugfixes, including stability bugfixes, retopo/modeling... - fixed RenderMan freezing at the start of render. - Snapping corrected, was just not working at all. - Fixed painting/sculpting along the curve. 4 5 Link to comment Share on other sites More sharing options...
Advanced Member Scary M Posted April 10, 2021 Advanced Member Share Posted April 10, 2021 (edited) Still no Wintab without that odd offset here. Tablet PC Works but Ill wait til we get wintab working. as I at least get VERY choppy perfomance trying to use Tablet PC Edited April 10, 2021 by Scary M Link to comment Share on other sites More sharing options...
Advanced Member gbball Posted April 10, 2021 Advanced Member Share Posted April 10, 2021 40 minutes ago, Scary M said: Still no Wintab without that odd offset here. Tablet PC Works but Ill wait til we get wintab working. as I at least get VERY choppy perfomance trying to use Tablet PC Confirmed on my end too. What kind of tablet are you using? Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted April 10, 2021 Reputable Contributor Share Posted April 10, 2021 17 hours ago, Frimasson said: 2 cents : The new super relax brush is FANTASTIC to clean rough scans You should add a " super relax whole model" in one click tool There actually is something like it, in a sense. In Surface Mode, you can click SMOOTH ALL at the bottom of the tool panel and have options for relaxing the whole model. You can even use the FREEZE brush to select areas where you DO NOT want to smooth/relax, or switch it in the dialog to smooth what is selected. Link to comment Share on other sites More sharing options...
Member roentgen Posted April 10, 2021 Member Share Posted April 10, 2021 (edited) After Baking, 3d-viewport still keeps Retopo room content despite room switching. You can't paint normally. Edited April 10, 2021 by roentgen Link to comment Share on other sites More sharing options...
Member oah1981 Posted April 10, 2021 Member Share Posted April 10, 2021 Hello I posted previously a bug in v40 in terms of the voxel brushes not working, v42 has fixed this, but I have discovered that putting 0 (zero) spacing in the brush options for surface and voxel brushes means that the brushes do not work (v42). Very small spacing also causing strange artifacts- i.e. depth not properly being shown, it just causes the edges of the brush to be slightly raised and textures the surface. Spacing of 0.1 is okay, but odd things happen at circa 0.01 spacing and no brushing at all at 0. Thanks Link to comment Share on other sites More sharing options...
Advanced Member Scary M Posted April 10, 2021 Advanced Member Share Posted April 10, 2021 9 hours ago, gbball said: Confirmed on my end too. What kind of tablet are you using? Wacom Intuos 4 pro Link to comment Share on other sites More sharing options...
Advanced Member Scary M Posted April 10, 2021 Advanced Member Share Posted April 10, 2021 If it helps ive been looking at the amount it offsets and it seem relative to the cursors position on the screen, The UI scales funny even more so in fullscreen is 3d coat running at some locked internal resolution or weird scaling? Like Half the resolution of my 4k monitor?? Link to comment Share on other sites More sharing options...
Member TheFlow Posted April 10, 2021 Member Share Posted April 10, 2021 Man, that Kitbash Room looks ACE! Great work 1) There's a strange Wacom (Intuos Pro) cursor offset for me also, the cursor appears like 100 or 200pixels left from there my pen actually is. 2) The UI scaling on my 4k screen looks "blurry", is there a way to natively use 3D Coat for HiDPI screens? Link to comment Share on other sites More sharing options...
Advanced Member Scary M Posted April 10, 2021 Advanced Member Share Posted April 10, 2021 (edited) 28 minutes ago, pattanner said: Just installed B42. Curve brushes still not working properly here: Simple vertex line and Vertex curves has no effect. Curve stroke has an effect but results are offset: Square, rectangle, vertex, stroke, circle and ellipse lasso all work as expected. With the closed spline draw mode, pressing Enter after creating the curve has no effect And selecting apply curve creates strange offset results: I think it's all related to the offset bug that make the beta unusable for some. The offset is still presenting for me when using tablet pc in preferences some tools work ok but in others the cursor jumps to where the offset would have been in between strokes and make things un workable for any sculpting task. Edited April 10, 2021 by Scary M Link to comment Share on other sites More sharing options...
Advanced Member Scary M Posted April 10, 2021 Advanced Member Share Posted April 10, 2021 22 minutes ago, TheFlow said: Man, that Kitbash Room looks ACE! Great work 1) There's a strange Wacom (Intuos Pro) cursor offset for me also, the cursor appears like 100 or 200pixels left from there my pen actually is. 2) The UI scaling on my 4k screen looks "blurry", is there a way to natively use 3D Coat for HiDPI screens? Yup try it in fullscreen using alt + Enter scales oddly, not just blurry but pixelates. Also as you move the cursor from right to left does the offset change in size? 1 Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 10, 2021 Author Share Posted April 10, 2021 Our programmer works over offset issue, it is related to 2-monitors systems with different resolutions. Set same resolution on both mons temporary, until it will be resolved. 4 Link to comment Share on other sites More sharing options...
Advanced Member thinkinmonkey Posted April 10, 2021 Advanced Member Share Posted April 10, 2021 I tried different shapes, you know, the default ones at startup, and it seems to me curve stroke works only with the second sphere: I tried also the cylinder, the little sphere, the head and the second body with unpredicatble results. I made test on my laptop with hd full resolution screen 17" and on Cintiq 13" in full hd: the second sphere is good. Dunno if it can be of any help for you, devs. Link to comment Share on other sites More sharing options...
Advanced Member gbball Posted April 10, 2021 Advanced Member Share Posted April 10, 2021 Hey everyone, for anyone interested, I'm streaming my use of the 2021.42 Link to comment Share on other sites More sharing options...
Member gnulinuxkernel Posted April 10, 2021 Member Share Posted April 10, 2021 During the painting process with wacom/Veikk tablets i had the annoing issue where after you painting something on point A and going to point B the application decides to paint a straight line, i was have this issue in 4.9 as well and i think even earlier, i just don't use tablet in 3d coat before, so i use ctrl+Z every 20 seconds when painting. I was check on Wacom and Chinese tablets, they both almost new and work fine in other apps, but not in 3d coat, Mode in settings TabletPC 2021-04-10_15-15-52.mp4 Link to comment Share on other sites More sharing options...
Advanced Member gbball Posted April 10, 2021 Advanced Member Share Posted April 10, 2021 6 hours ago, Scary M said: Wacom Intuos 4 pro Yeah, I'm using something else, but Andrew has confirmed that it's an issue of monitor resolution when you have multiple monitors and one is at a different resolution. I was able to fix by changing the resolution to HD Link to comment Share on other sites More sharing options...
Member gnulinuxkernel Posted April 10, 2021 Member Share Posted April 10, 2021 1 hour ago, gnulinuxkernel said: During the painting process with wacom/Veikk tablets i had the annoing issue where after you painting something on point A and going to point B the application decides to paint a straight line, i was have this issue in 4.9 as well and i think even earlier, i just don't use tablet in 3d coat before, so i use ctrl+Z every 20 seconds when painting. I was check on Wacom and Chinese tablets, they both almost new and work fine in other apps, but not in 3d coat, Mode in settings TabletPC 2021-04-10_15-15-52.mp4 I was updated my drivers on Wacom and Veikk (china tablet) and Veikk still work bad, but Wacom work just fine suddenly, 15 minutes no such issues, Previously i was send info about problems with "Sliding stencils alpha" and strange pen paiting issue when all painting was pretty rough until reboot program. Maybe this chinesse tablet was a main problem. But i was check a wacom too before and he was had those problems (now all good suddenly). I just think now you need set up priorities about my issues to bottom line because i'm not sure maybe my tablet was a problem. Anyway if in future if i have some issues with wacom i will post here, for now i don't have a problems =) Link to comment Share on other sites More sharing options...
Advanced Member Scary M Posted April 11, 2021 Advanced Member Share Posted April 11, 2021 Version b42 Bug - loading the default surface sphere and using Rapid smooth as soon as i lay a stroke i get subdivision of that stroke, regardless of the Modify connected check box or the subdivision settings. Link to comment Share on other sites More sharing options...
Advanced Member animk Posted April 11, 2021 Advanced Member Share Posted April 11, 2021 1 hour ago, Scary M said: Version b42 Bug - loading the default surface sphere and using Rapid smooth as soon as i lay a stroke i get subdivision of that stroke, regardless of the Modify connected check box or the subdivision settings. Remove stretching? Probably not a bug. Link to comment Share on other sites More sharing options...
Advanced Member Scary M Posted April 11, 2021 Advanced Member Share Posted April 11, 2021 I C.... Guess i never noticed it did that to geometry Its actually quite neato. Link to comment Share on other sites More sharing options...
Advanced Member Grimmy Posted April 11, 2021 Advanced Member Share Posted April 11, 2021 In B42.. Extrude faces still just seems to move the face and nothing more. Normal Extrude works but the process is very cumbersome. Each time I want to extrude a new face a need to deselect all faces (double clicking outside the mesh to deselect all does not work with two monitors unless you first click on the second monitor), select a new face, select the extrude tool AGAIN and then drag it out. Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted April 11, 2021 Advanced Member Share Posted April 11, 2021 On 4/9/2021 at 1:51 PM, Andrew Shpagin said: 9.04.21 B42: - Voxel brushes updated, voxel brush engine introduces, similar to surface brush engine. Pay attention, VoxelEngine is subject to change, so we can't guarantee your presets related to the voxel engine will be preserved. Anyway, it is faster, more flexible. And very good point it offers real clay-like brushes for voxels. - A lot, lot of bugfixes, including stability bugfixes, retopo/modeling... - fixed RenderMan freezing at the start of render. - Snapping corrected, was just not working at all. - Fixed painting/sculpting along the curve. Big difference Lots of amazing stuff in 2021 Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted April 11, 2021 Advanced Member Share Posted April 11, 2021 this isnt a bug but its something to note inside blender i can comfortably sculpt at 50 million polys its slow but you can stamp details easily inside 3dc i can even get 50 million polys... it just crashes, i know you dont need that many but its just something to note. Link to comment Share on other sites More sharing options...
Advanced Member gbball Posted April 11, 2021 Advanced Member Share Posted April 11, 2021 1 hour ago, Elemeno said: this isnt a bug but its something to note inside blender i can comfortably sculpt at 50 million polys its slow but you can stamp details easily inside 3dc i can even get 50 million polys... it just crashes, i know you dont need that many but its just something to note. I just tested and I got to 63 million triangles pretty comfortably. A little slow, but it seemed like I could go higher if I wanted. 2 1 Link to comment Share on other sites More sharing options...
Member TheFlow Posted April 11, 2021 Member Share Posted April 11, 2021 On 4/10/2021 at 2:22 PM, Scary M said: Yup try it in fullscreen using alt + Enter scales oddly, not just blurry but pixelates. Also as you move the cursor from right to left does the offset change in size? Thanks! Yeah it gets sharper but now is pixelated and everything looks like 2px instead of 1px. Yes, the further right my hand/pen is, the closer the cursor is to where it should be. Totally seems related to my second monitor. Using 1920x1200 (left) and 4k(right, main monitor). Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted April 11, 2021 Advanced Member Share Posted April 11, 2021 30 minutes ago, gbball said: I just tested and I got to 63 million triangles pretty comfortably. A little slow, but it seemed like I could go higher if I wanted. awwww.... ill try again, i only have a 10850k and 32 gb ram , what you currently running? Link to comment Share on other sites More sharing options...
Posted by Andrew Shpagin,
5 reactions
Go to this post
