Advanced Member Callak Posted April 6, 2021 Advanced Member Report Share Posted April 6, 2021 (edited) I found the Unify UVs button, it seems to dump the UVs from all my materials into one UV map, can I do that accept do it only for specific materials? I also found the "Move selected faces to another UV set option" however, when I select another UV set from the drop down list, nothing happens. Edited April 6, 2021 by Callak Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 6, 2021 Report Share Posted April 6, 2021 Hi You can do what you want, since selecting all faces = selecting that UV set. And up there in the top left of the UI, you should see a "[Move Selected]" drop down list, which is where you would choose to move one UV set into another. Quote Link to comment Share on other sites More sharing options...
Advanced Member Callak Posted April 6, 2021 Author Advanced Member Report Share Posted April 6, 2021 Yes, I'm trying to use that to move "Beard" to "Face Scales" but when I have "Beard" selected, and I select "Face Scales" from the drop down list, the "Beard" UV does not appear on top of the "Face Scales" UV like I would expect. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 6, 2021 Report Share Posted April 6, 2021 Sorry, cant replicate this issue. - Select UVset - Select islands or faces - move selected to other UVset - Done ! Quote Link to comment Share on other sites More sharing options...
