pattanner
Unable to bake either in B39 or B40
Anybody else having issues with baking?
Even with a simple primitives cube created in the retopo room, seams marked and unwrapped, then retopo mesh copied to sculpt room to provide a baking target,
3D Coat simply shuts down without error messages (both B39 and B40 versions)
Edited by pattanner
Sorry meant to post in 2021 Open Beta test
Hi
Testing B40, i can bake without any issues.
Please try again turning off Zup_coordinates.
After testing(B40), I have the same issue.
In V4, it is baked fine with the same option.
2021_Bake test.3b
▲ Test file
Edit 1)
I tested it on two different computers [ Bake W/ Normal map (Per-Pixels) ]
The baking process window will not appear and will immediately turn off.
Edit 2)
In V4, this message appears, but the baking proceeds fine.159862390_2021-04-07231405.jpg.6bcee45006650a087024d1062717e000.jpg
Edited by Yousung
Sculpt layers Beta on V4 it is not compatible with B39/40.
Some projects are probably not compatible either in between versions.
It is better to finish them in the version in which they were started.
Testing was first performed on the B40 version.
Crush happened and then I tried it on the V4 version.
There seems to be something wrong with the beta version of the baking.
1 hour ago, Carlosan said:
Hi
Tried with z-Up disabled, same issue - immediate shutdown of 3D coat.
Also not a layers issue as its a cube primitive created in B40.
No issues baking in 4.9.72
To report this bug send support-related questions at
support@3dcoat.com
and
andrewshpagin@gmail.com
Thanks
