New Member sprias Posted April 20, 2021 New Member Report Share Posted April 20, 2021 Hey everyone, I've been having trouble trying to get a brush in 2D-Paint to work, with some behaviors coming off as inconsistent as I try every toggle I can find. I'd like to set a brush to vary only in radius, while depth remains constant despite pressure. Thus far I've tried every combination of toggling between pressure sensitivity, altering the curves to be a flat response, and seeing if anything responds within the brush panel. Thus far, my findings are; depth will respond to pressure even when toggled off, or when the pressure curves are set to constant (edit curves -> bring bottom left point to the top) unless radius is also set not to respond to pressure. However, after this, when radius pressure sensitivity is toggled back on, it doesn't respond unless depth is similarly toggled to respond. This occurs with or without depth lock. I figured I can just use the freehand lasso draw setting in 2D-Paint, but it'd be good to know in the future if I'm doing anything wrong. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 20, 2021 Report Share Posted April 20, 2021 Hello Check tablet settings on preferences Quote Link to comment Share on other sites More sharing options...
New Member sprias Posted April 20, 2021 Author New Member Report Share Posted April 20, 2021 Hey Carlo, Thank you, but when I want it to the sensitivity responds just fine. I'm having trouble creating settings so that the pressure only affects radius and nothing else. Toggling Depth to not respond (clicking between the pressure and mouse toggle) or editing the curves to be a flat, max response does nothing unless I toggle Radius sensitivity off as well, which defeats the purpose. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 20, 2021 Report Share Posted April 20, 2021 Hello You mean Stroke Modes ? https://3dcoat.com/manual/general/321-strokemodes/ Quote Link to comment Share on other sites More sharing options...
New Member sprias Posted April 22, 2021 Author New Member Report Share Posted April 22, 2021 Yes. I'm trying to set the stroke mode so that only the radius responds to pressure; not the depth. However, when I lock the depth or even adjust the curves to be a flat response, nothing happens. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 22, 2021 Report Share Posted April 22, 2021 Constant Pressure stroke is not working as expected ? Quote Link to comment Share on other sites More sharing options...
