3D Art Pipeline in 3DCoat 2021: Low-Poly Modeling, Sculpting and Texturing.
This video shows the process of creation a still life artwork from scratch using various tools available in 3DCoat 2021. The program allows you to create everything from start to finish without leaving 3DCoat (except Ray Tracing rendering, which is still in progress for now).
  • 1 month later...
Hi! I just wan to know how make crisp edges in low poly modeling with live smoothing? I Rhino 7 , for example, while modeling in sudivs I can select some edges and just make them crisp - so subdiv smoothing is not applied to this edges
Edited by iRadovsky
@iRadovsky hope this can help,
Here is a simple model in modeling room, it has sculpt mesh sync turned on but without subdivision for now.
Subdividing it, it will look as how you expect, all smoothed one iteration
In retopo room, under tweak, you have the tool "sharp edges"
Here, I shift-LMB clicked a loop with this tool, to mark the edge loop as sharp. "Sharp" edge appears blue/cyan in the viewport, this is true for imported models as well.
Lastly, in model room again, subdividing this time produces a sharper edge and geometry to accommodate sharp edge, where the sharp edge was marked
