[Solved] Extreme graphical artifacts when painting
  • New Member
So, I just installed the Beta, want to go into the painting room to try it out and immediately I get these artefacts that you can see all over the UI.
It grows in size as I hold the pen pressure or left mouse button.
Am I the only one experiencing this?
Hope this post was useful!
  • New Member
15 hours ago, Carlosan said:
Hi !
The beta version is only compatible with GL not with DX, is your graphics card compatible ?
If yes: Are graphic driver uptodate ?
I see, well i run a RTX 3070 on the latest Nvidia drivers. should I let the program be run by the iGPU ? Thanks fo the response
Edit: i just tried to run it via the iGPU but it doesn't seem to make a difference for me
  • New Member
I have re-installed my drivers and it seems to have fixed the problem.
  • Carlosan changed the title to [Solved] Extreme graphical artifacts when painting
