@SERGYIWill there be development for Wayland display server in linux? 3Dcoat will run using Wayland, but is unusable due to extremely low frame rates in the viewport.
14 hours ago, Andrew Shpagin said:
please run coat, exit in minute or half, send me docs/3DCoat2021/log.txt
And move mouse constanlly during the process
Hi.
The low Framerate from 84 is gone in version 85.
Thank you! :yes:
Testing .85:
-Encountered the most entertaining bug: I vox hid a part, objectified it, deleted hidden from the base. Switched to it. I was scaling the part using transform tools inner yellow cube.
I literally watched the left symmetry indicator move further left by itself breaking the symmetry. Object became non uniform. I right clicked and made it uniform. Although symmetry is still active none of the brushes work symmetrically. The rogue sym dot is nowhere to be seen again :D :D. I tried symcopy to fix, didnt work so I'm typing this :D
-edit: I hid a part of the rogue mesh and objectified it. sym still doesnt come back...Sym works for other parts I made from the same base though :D
-edit 2 : When I smooth using shift, Smooth adds a single brush stroke when the shift is released. For ex: I used vox clay on a vox obj. I started smoothing using shift key. When I'm done I release the shift and a stroke of vox clay is added unwantedly. This is not a new bug.
-edit 3: Performance feels better for now.
This software has a mind of its own :D
Edited by Koray
for more
2 hours ago, Koray said:
Adding a screen cap for the smooth bug. No matter how I try, I cant lift the pen up without adding those strokes
So, you press SHIFT, mouse down, move, mouse up, SHIFT up, and quad appears? In sphere tool? Or in all native voxel tools?
Since you asked, I tested further and ONLY the Vox Clay adds a square when:
- You select vox clay, add strokes, press shift start smoothing, unpress shift without releasing the mouse left click or pen pressure, then when you release the left click or lift the pen, only the Vox Clay adds a single stroke even if you try not to move the mouse or pen.
Seems like the vox clay counts mouse release (or pen lift) as a stroke . No other brush that I've tried does that.
When you release the mouse or pen while holding shift the stroke does not appear.
Edit: I used the sphere tool to draw the arrows to show you the squares.
Edited by Koray
20 hours ago, Elemeno said:
well 200 million triangles was my limit ... after that sculpting is 30 fps and a little slow... probably ok for stamping
Is that a single tool that is 200 million???
In my case I can go up to around 20 mil on a single tool, then the brushes start acting quite slow. Then I tried smooth all from the space menu and 3DC crashed.
( my pc: i9, 64 gig ram, 1080ti gpu )
I am on 85. There is a render room bug still. If you customize the shader and go to render room the changes are not present. Then when you go to the sculpt room back, the standard shader is on the sculpt, so the customized settings are gone. Is there a work around? I think this started with v84 or v83.
