4 hours ago, Carlosan said:
I renamed docs folder and install. Everything works fine
It works here too, thanks! :good2:
- Grey out under modal dialogs is optional (Prefs->Theme), it does not shades the BG under color pickers.
Thank you so much ! This was going to be the second most annoying thing for me in 3d-Coat (nothing can beat the annoyance of the right click menu in retopo room).
  • Haha 2
Hi. I would like to share my experiences with smartmaterials shortly. Exr files work fine for Depth Painting! But you have to set the 'locked depth' something like a hundred times bigger to work. If I compare in my case the depth.jpg with depth.exr, I have to set the 'locked depth' of the jpg to 0.5, whereas the exr file has to be set around 50 to get a compareable result. (The result btw. is less noise which is very good, so it works!)
One funny thing is, when you press the unlock button, the preview to the right shows correct displacement, and when you press lock, it flips to the wrong side again.
It would be nice if the exr file preview would work. But I mentioned that already.
When you Import Materials, you have to create and select the folder before to get it in the right place.
Thank you. 02. is great so far!
1 hour ago, wilson66 said:
So, I can update to 3D Coat version 2022.02 using the versions manager, but I can't actually use it or purchase an upgrade yet for that version (I have 2021). Is that right?
Unless I have misunderstood your question, version 2022.02 should use the 2021 license you purchased.
Andrew.
Andrew.
Yes, thanks, it works now. I was trying the wrong password to log in... :/
for ease and speed can we have an option where scaling,extrusions or anything uses a slider ... could we make it so the mouse movement is the slider... positive movement outwards and negative movements inwards
[ Modeling/Retopo Room issue ]
- For the Inset tool, the changed value is applied even if you click Cancel.
It starts working normally again on the same mesh.
I don't know the cause...
- Edge - Collapse is still not centered.
[ Modeling/Retopo Room improvement request ]
When using 'Mesh - Sculpt Mesh & Unlink Sculpt Mesh', can you add an option so that it is applied only to the desired polygroup, not the entire polygroup?
In particular, in the case of 'Unlink Sculpt Mesh', it creates unnecessary SculptTrees every time and makes it complicated.
Edited by Yousung
Sorry for not writing all at once...
- If you lower the Scale value to make it flat on a specific axis of the Transform (there is no Align function...), the polygon moves very unstable.
In 3DC 2022.03, brush and strength control using RMB doesn't seem to work when using the Blob tool. Can anyone confirm?
Or is this maybe related to the Blob tool not using regular brush stroke types?
Edited by Metin Seven
