[Fixed] 2021.23 - 1 second lag after every stroke while sculpting
Go to solution Solved by Andrew Shpagin,
I loaded up the default sphere in the sculpting room and after every stroke (even clay fast) there's a 0.5 - 1 second lag where the cursor is unresponsive.
Windows 10 , RTX 3090, 64GB ram, latest video card drivers, Ryzen 5950x
Tried with Multicore optimzation setting on and off. same result.
Any suggestions?
  • Carlosan changed the title to 2021.06 - 1 second lag after every stroke while sculpting
  • 2 weeks later...
On 7/21/2021 at 2:01 PM, TomasAceytuno said:
Same issue with Huion tablet but Works fine with mouse.
3dcoat mac 2021.6
For what little help I can contribute, I use a Hunion tablet on PC, never had this issue on any version, the issue might be Mac or driver related for ThomasJohan?   Just a thought.
Edited by Callak
  • Carlosan changed the title to 2021.22 - 1 second lag after every stroke while sculpting
  • Carlosan changed the title to 2021.23 - 1 second lag after every stroke while sculpting
On 8/7/2021 at 11:06 AM, gerykats said:
Same issue for me with 2021.22...
@spayer...i checked it...same problem...
Does anyone can share me the install of 2021.11..??Thanks
The URL's are easy to edit to change which version you want to download.  Here's 2021.11
https://pilgway.com/files/3dcoat/2021/3DCoat-2021-11.exe
Nope, it's not about driver. I have same issue with Kamvas Pro 24 on Windows 10 - it works perfectly fine in V4, but it's a mess in 2021(except 2021.18). WinTab, no strokes(it worked in 2021.18 and works in V4), WindowsInk/TabletPC, strokes/pressure are working, but with lag on very beginning of every stroke... well, whole ui have this lag, viewport or left side tool panel scrolling suffer from this issue. That's issue is clearly on 3D-Coat side.
I really want to fix the lag issue, but can't reproduce it. So I need some help to understand what changes caused it.
1) There are 3 links- 17, 18 and 19. Is it right that 17 lags, 18 not lags and 19 lags again?
https://pilgway.com/files/3dcoat/2021/3DCoat-2021-17.exe
https://pilgway.com/files/3dcoat/2021/3DCoat-2021-18.exe
https://pilgway.com/files/3dcoat/2021/3DCoat-2021-19.exe
2) Does it lag over the simplest scene - PPP, default cube, draw strokes of radius 0.05 over one side. Does it depend on radius? Does it depend on Wintab/TabletPC? In which version?
Thanks for your patience and reporting.
  • Carlosan changed the title to [Fixed] 2021.23 - 1 second lag after every stroke while sculpting
