Advanced Member jimhatama Posted July 22, 2021 Advanced Member Report Share Posted July 22, 2021 These brushes work really bad in 2021. They either push or pull too much, they dont produce hard edges or straight planes. The normal calculation is all wrong for them. They are very hard to control and results are bad. 4.9 Chisel was much better let alone zbrush hpolish. this kind of surfaces are pain now In 4.9 its ok zbrush hpolish produce ideal lines 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member jimhatama Posted July 22, 2021 Author Advanced Member Report Share Posted July 22, 2021 after a long testing/changing things I find that new chisel brush completly unusable for a work. Maybe we could get old brushes added back? As an alternative 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 22, 2021 Report Share Posted July 22, 2021 10 hours ago, Andrew Shpagin said: Yes, reproduced it, will fix it. I need some help with Chiesl to make it perfect. Seems it works symmetrically on my side, but I use simple models. So, if someone will drop me some scene where I can reproduce it, that could be good. Also, if someone was able to tweak the Chisel to the expected job, please send me the preset to andrewshpagin@gmail.com. Quote Link to comment Share on other sites More sharing options...
Advanced Member jimhatama Posted July 22, 2021 Author Advanced Member Report Share Posted July 22, 2021 For symmetry its easy to reproduce. Enable buildup, set it high abt 33-50, symmetry will be broken. (use average normal) Quote Link to comment Share on other sites More sharing options...
