[Fixed] Color picker bug and Brush size problems
Hi, I found two problems that are stopping me to continue using the software you can see my frustration in the video example, every time I use the color picker it switch back to the previous color, second the brush size get super big and every time use the fill color switch back to the original size.
Is my scene to small now? Please let me know if there is a fix for this I don't want to give up with 3d coat 2021.
I'm using 2021.17 but the same happen in .16
  • Carlosan changed the title to [Fixed] Color picker bug and Brush size problems
On 8/1/2021 at 11:37 PM, Carlosan said:
Yes your model is frankly small.
As i remember you got issues baking AOs because model was big.
Try to fit the model inside grid guides.
Hope it help
Hello carlosan..;i seen your pict with a grid in XYZ axis...where can i set it please..???
