How to get rid of sharp edges in 3d-Coat
Carlosan
On 8/9/2021 at 11:51 AM, digman said:
There are a couple of ways also in 3DC.  One way below:
Select Under the polygroup panel the correct layer
At the bottom of the polygroup panel are icons. The third one on the right is select all faces on that layer.
Next, top panel  click on the Edges icon.  Now all the edges are now selected.
In the Left bar tool panel.
Scroll to "Selected"  Choose Clear sharp.
The other way.
E-Panel, Select the rectangle laso.
Deselect Ignore Back Faces. Be sure to select Ignore back faces on again when done with your work.
Draw the rectangle around the whole model.
All edges are selected.
Scroll to Selected again and do the same process as before.
  • 1 year later...
