Member Andre Posted August 17, 2021 Member Share Posted August 17, 2021 Hey Forum (noob question) I don't think I see it in any of the brushes, but is there a tutorial or technique... in trying to clone/rubber stamp geometry from one part of a sculpture to another part? For example, I have tree bark texture from 3D scanning, I'd like to clone this bark texture geometry into other parts of the tree. There's no texture map, it's all just geometry. I'm thinking of cutting and pasting the geometry from 1 area into another, but I'd rather use a brush. Possible?? thank you Quote Link to comment https://3dcoat.com/forum/index.php?/topic/25980-solved-is-there-a-3d-cloning-tool-or-technique/ Share on other sites More sharing options...
Reputable Contributor digman Posted August 17, 2021 Reputable Contributor Share Posted August 17, 2021 I take it your scanning software exported the vertex color instead of creating a texture map. A little hard to answer as I do not know for sure which room you are in. I would guess Sculpt room in Surface mode which will display vertex colors. Correct.? I await your answer before going forward. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/25980-solved-is-there-a-3d-cloning-tool-or-technique/#findComment-176266 Share on other sites More sharing options...
Member Andre Posted September 8, 2021 Author Member Share Posted September 8, 2021 I'd love to find a way (like the new Copy tool in surface mode) but in the voxelized sculpt toolkit I'd like to clone/rubber stamp geometry from one area and brush it in another area on the 3d model. Think of Photoshop's clone tool, but with geometry and in a brush. Possible? Or is this a brush I'm not familiar with in the latest version? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/25980-solved-is-there-a-3d-cloning-tool-or-technique/#findComment-177018 Share on other sites More sharing options...
Advanced Member Yousung Posted September 8, 2021 Advanced Member Share Posted September 8, 2021 In the Clay/Draw item on the left panel, There is something called Copy Clay. (both in Voxel / Surface.) Perhaps this is similar to what you want. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/25980-solved-is-there-a-3d-cloning-tool-or-technique/#findComment-177019 Share on other sites More sharing options...
Solution Carlosan Posted September 11, 2021 Solution Share Posted September 11, 2021 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/25980-solved-is-there-a-3d-cloning-tool-or-technique/#findComment-177084 Share on other sites More sharing options...
Member Andre Posted January 25, 2025 Author Member Share Posted January 25, 2025 Thank you Carlosan and Yousong. Both of these suggestions are very good. CopyClay is my quick and easy solution, however, I think using sculpt layers to clone with a paintbrush, might be more powerful and allow more control. I'll have to rewatch the video a few more times to let it all sink in... thanks! 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/25980-solved-is-there-a-3d-cloning-tool-or-technique/#findComment-197953 Share on other sites More sharing options...
