Carlosan Posted September 16, 2021 Report Share Posted September 16, 2021 (3D-Coat version 4.7) Here's a quick and easy way to add a repeating pattern or ornament to your normal map in 3D-Coat. Just make sure that you have a UV map, preferably one that's as straight as possible. Then, add a new layer in paint room, and select stencil. From the floating control window, use magnifying glass to scale the texture into good size, and select UV map as projection method. Now, rotate the object to see where the seam is and try to align the pattern so that seam is not visible. You can either paint this in or use the paint bucket. Voila. Subscribe to my channel at: https://www.youtube.com/channel/UC9QkB75gHRy-wXQQM4oydmQ?sub_confirmation=1 Thank you for watching. Please visit my website www.creativewithjaakko.com Quote Link to comment Share on other sites More sharing options...
