[Solved] Retopo Mesh is not smooth but facets only
C3D_
Go to solution Solved by Yousung,
Hello forum,
I made a retopo mesh in 3DCoat (Insta Mesh). The problem is that all faces are shaded flat.  Facetes.
So when i send it over to the paint room (Bake w/ Normal Map (per pixel)) the generated Normalmap also has these facets baked in.
If this would not be the case i actually would not care since the model is shaded fine in my 3D Software.
How can i switch to smooth shading??
I do not wanna subdivide any further. I tryd it but the facets stay (Just smaller polygons).
Thank you!
Edited by C3D_
Solved
Hello,
@Carlosan thanks for reply.
I updated 3DCoat to 2021.53 but the problem persists although i found out what it is.
Almost all edges are marked as "Sharp Edges"... colored turquoise in the viewport.
I found that with the Retopo->Tweak->Sharp Edges Tool , i can mark the few black edges that are left also "sharp" and they turn turquoise.
Okay, thats all great and nice... but HOW do i turn them back into "SOFT Edges" ??
There is nothing in the docs about it....
Thanks!!
  • Solution
Carlosan
Yousung was awarded the badge 'Helpful' and 1 points.
Select an edge with the Set.Sharp tool in Selected and use Clear Sharp.
@Yousung Hello and thanks.
Okay... Just found it also out myself the hard way.
I get the idea of case sensitive menus... but if you dont know the tools and philosophy of the software
then you are lost.
A non global approach:
1. Add Geometry -> Select
2. Operate over Edges MUST be selected (Case sensitive menu!!)
3. Select all Edges on the mesh you wanna set to smooth
4. Selected -> Clear Sharp
Edited by C3D_
  • C3D_ changed the title to [Solved] Retopo Mesh is not smooth but facets only
