Carlosan Posted September 23, 2021 Share Posted September 23, 2021 You had two copies of the same model, but with two vastly different UV sets applied to each. Is there a way in which 3DCoat could look at this model with this texture and then use that information to paint the second model and its UV set to look as identical as possible to the first ? This videos covers one easy method in 3DCoat, to modify a model's UV's after doing some texture painting work... without any penalty. Quote Link to comment Share on other sites More sharing options...
