[Solved] Lasso Selection - Adding to current selection
DustyShinigami
Go to solution Solved by poeboi,
Hi
Am I dreaming here, or am I right in that you can add more to your selection with the Lasso tool...? What I mean is, when you use the Lasso to select multiple faces, is there a key you can press so you can lasso select some more faces in addition to the ones selected? I coulda sworn you could... In Maya, you hold Shift I believe. When I've tried a combo of Ctrl, Alt, and Shift, nothing seems to happen. The most I can do is deselect faces when going over new ones.
On which room ?
On Modelling room you can use Expand tool
  • Solution
Carlosan
poeboi was awarded the badge 'Helpful' and 1 points.
Hello, hope this can help
It's
make selection → LMB press first, then while holding LMB, press shift → drag another selection area, release LMB
(Also works with, LMB press first, then hold CTRL, and release LMB to deselect)
Sorry, I should have mentioned - it's in the Retopo room.
But thank you, poeboi! That works perfectly. :D
