Member Marlo Posted October 15, 2021 Member Report Share Posted October 15, 2021 (edited) If I import a model as child objects I realized that I actually can't do that. On import (even with "w/o Voxel") all sublayers turn into voxel layers. This means if I just touch the mesh it will go broken. Artifacts happen and also mesh starts to shrink. This is already the second time I opened a thread within a day. I'm sorry this but also I wish 3D Coat was way more industry friendly. It is frustrating that I cannot import a mesh into 3d Coat and and continue to work on it. I spent several hours on it with no success at all. It only works when I import a single object, subdivide it flat and put it into surface mode. Then I can also convert it into a voxel layer afterwards. The thing is when you import multiple objects as child objects at once just the parent gets surface mode (with "W/O Voxel" checked). Not it's children. Meeeeh. PS: Importing the mesh in an voxel layer kills a lot of details. Even at higher densities. I basically want to stay in sculpt room and get more control. The thing is if I subdivide my objects before import the mesh in V mode doesn't shrink anymore because it can hold its form. Though V mode is not what I want. Edited October 15, 2021 by Marlo Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted October 15, 2021 Reputable Contributor Report Share Posted October 15, 2021 The bug has been reported. I would imagine it will get fixed soon. Edit: I take my words back. In Version 2021.62 the Import feature( left tool panel) in surface mode does not import as surface mode parent and surface mode children. 1 Quote Link to comment Share on other sites More sharing options...
Member Marlo Posted October 15, 2021 Author Member Report Share Posted October 15, 2021 8 minutes ago, digman said: The bug has been reported. I would imagine it will get fixed soon. Surface mode has an import feature (left toolbar) as well. No need to select w/o voxels. The object and children will import as surface mode objects. Edit: I take my words back. In Version 2021.62 the Import feature( left tool panel) in surface mode does not import as surface mode parent and surface mode children. That's good to hear! Quote Link to comment Share on other sites More sharing options...
