Problem with imported displacement and smart material 'more on' BUMP' applying on surface
Hello Guys,
here is my problem.
I would like to use some externelly made displacement/height images for some sci-fi panels painted outside of 3D Coat.
My steps:
1. I import the displacement (it appears on the model)
2. I bake occlusion, curvature
3. I would like to check preview (most of the cases preview simple does not shows the imported 'height/bump' effect, but I could survive that as it applies after using fill tool (but it is a bug IMHO)
4. I would like to create an extra layer where dirt, worn parts are INSIDE the lower parts and/or On the top of the higher parts (so the worn is affected by the height map and geometry is NOT affected at all).
- I use 'more on bumped' and 'more on dent' projections, nothing really works.
- I copied the height info to the actual layer's height channel I'm working on (doesn't help)
Do you have any idea how solve this properly?
Thanks
TomTom
I used to use Paint UV-Mapped mesh as my meshes are UV-mapped already, I need the separate  textures options, etc. How this will solve the problem of my existing project I work on for days? What will it add to the workflow and what will be removed by this? Thanks.
To work with displacement maps you need high poly density. That is why preview simple does not shows the imported 'height/bump' effect.
Because there is only a grey map that was apply as Color Standard Blend, the mesh dont have lower parts and/or top of the higher parts.
 It is not possible for PPP to calculate what you need for your project due to the lack of information in the object mesh.
In some cases (like Concave, etc.) it shows (see the screenshots), so no high poly needed at all.
It was imported as Displacement as I wrote.
Technically it seems to me a simple bug/bad implementation of a feature. It should work (as it works with other projection types), just somehow there is somewhere a glitch.
10 hours ago, Yousung said:
sadly
- More on Bumped
- More on Dent
These two condition options seem to only work on layers with displacement applied.
On separate layers, this option does not work.
849257028_bandicam2021-12-1500-52-08-968copy.thumb.jpg.acf4f2710278fe54c768f1370ca3f799.jpg
Here I painted each layer and checked Bumped/Dent.
Layer height is applied individually.
I was not able to get what happens unfortunately. I used this approach, no fun. :(
But I use earlier version of 3D Coat (but it seems the problem exists since 2011 at least).
Edited by TomTom
