Member Cybergooch Posted December 22, 2021 Member Report Share Posted December 22, 2021 I believe the alpha brushes that are used in ZBrush can also be used in 3DCoat, but what about the vdm brushes? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 22, 2021 Reputable Contributor Report Share Posted December 22, 2021 I asked Andrew about Vector Displacement alphas as well, a few years ago. It's a better solution than the ON PEN option in the IMPORT tool, especially for repetitive objects like scales, spikes, teeth, etc...as you can apply many with a single brush stroke (using spacing) and you have better control using the Stamp Draw modes. 1 Quote Link to comment Share on other sites More sharing options...
Member Cybergooch Posted December 22, 2021 Author Member Report Share Posted December 22, 2021 Thanks for the replies, would be great to see! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 31, 2023 Report Share Posted March 31, 2023 Was added as an early release on 3DCoat-2023-11 - Preliminary (early stage) support of VDM alphas in Surface/Extruder tool. 3-channels, 32 bit EXR-s are treated as VDM-s. Later it will be extended (picking VDM-s from any raw surface, color, making VDM from any model, support VDM-s in voxels and in all brushes). All this is in gradual development, exposing just this small piece. Quote Link to comment Share on other sites More sharing options...
Member captainbuckfish Posted April 2, 2023 Member Report Share Posted April 2, 2023 Carlosan is there any documentation for this yet? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 2, 2023 Report Share Posted April 2, 2023 Not yet since it is being developed, but the process is simple. Create a new folder in Brushes where to load 32bits exr vdm alphas. Select Surface mode > Extruder tool Paint or stamp over the mesh. On Tool Option panel subdivision is helpful to add located detail and avoid to add res+ to whole mesh. - Video done by user MIKE: MIKE.mp4 The Pick & Paste Surface Sculpt Tool, located near the Extrude, allows you to grab a feature from a raw surface, create a Vector Displacement Map (VDM), and use it with Extrude to duplicate the feature. It doesn't require a flat or nice surface to grab the element; it automatically unwraps and flattens the edge. You can also export VDMs as EXR files to use in other applications. Additionally, you can add external VDM alphas (3 channels, 32-bit, EXR/TIFF) into the Alphas panel and use them in the Surface Extrude. Quote Link to comment Share on other sites More sharing options...
Member awhawkins Posted May 12, 2023 Member Report Share Posted May 12, 2023 On 4/2/2023 at 4:18 AM, Carlosan said: Not yet since it is being developed, but the process is simple. Create a new folder in Brushes where to load 32bits exr vdm alphas. Select Surface mode > Extruder tool Paint or stamp over the mesh. On Tool Option panel subdivision is helpful to add located detail and avoid to add res+ to whole mesh. - Video done by user MIKE: MIKE.mp4 3.03 MB · 0 downloads The Pick & Paste Surface Sculpt Tool, located near the Extrude, allows you to grab a feature from a raw surface, create a Vector Displacement Map (VDM), and use it with Extrude to duplicate the feature. It doesn't require a flat or nice surface to grab the element; it automatically unwraps and flattens the edge. You can also export VDMs as EXR files to use in other applications. Additionally, you can add external VDM alphas (3 channels, 32-bit, EXR/TIFF) into the Alphas panel and use them in the Surface Extrude. Carlosan, I have 3DCoat 2023.19 and I do not see the Pick and Paste tool. I went back to 2023.11 and could not find it there. Could tell where this tool is located? 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 12, 2023 Report Share Posted May 12, 2023 Hi VDM only works on Surface mode //edit if the tool it is not showed (I am testing v2023.19 and is working as expected): Try Reset to default settings Or press RMB over tool section and select Show all tools in Section Hope this help 1 Quote Link to comment Share on other sites More sharing options...
Member supereasy1001 Posted April 10 Member Report Share Posted April 10 Is there support for importing vdm's that were created for Z brush? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 10 Report Share Posted April 10 You need to export out ZBrush VD maps to be able to import it into 3DC. Quote Link to comment Share on other sites More sharing options...
