3DCoat questions
Metin Seven
Go to solution Solved by Евгений,
Hi,
I own 3D-Coat 4.9 and I've worked with it in the past, but have been using ZBrush and Blender the past few years.
The recent take-over of Pixologic by Maxon seems like the perfect moment to rediscover 3D-Coat. I've installed the latest 2021 version, and I get more and more enthusiastic as I go.
As I've been away from 3DC for years now, I'm refreshing my memory. Some questions:
1. Is there an equivalent to ZBrush's Repeat Last stroke ('1' key) ? I used that a lot in ZB to repeat the exact same stroke a few times when desired.
2. I couldn't get the numeric keypad keys to work in 3DC (5 to toggle perspective / orthographic, etc.). What could the cause be for that? The numpad keys work fine in Blender on the same system.
─ What's even weirder is that some numpad, like the + and - key, do work in 3DC.
3. What would be the 3DC procedure comparable to multiresolution sculpting in ZBrush and Blender (retopo, then subdivide and sculpt on different polygon subdivision levels) ?
4. Is there a 3DC equivalent to ZBrush's Insert (Multi) Mesh brushes?
5. What do I need to do to save the QuickAccess menu with my favorites (to port it to a new 3DC installation in the future) ? Is the menu saved along with the Hotkeys?
6. Is the old Angulator tool still present in the latest 3DC versions, or is there a new way of sharpening or beveling edges?
7. I'd like to upgrade my 3DC 4.x license, but when I bought it, I was using macOS. Right now I'm using Windows, but expect to return to macOS in a few months. Will I be able to switch between OS versions without issues or extra expenses?
Many thanks!
Edited by Metin Seven
Adjusted and added questions
54 minutes ago, Metin Seven said:
Привет,
У меня есть 3D-пальто 4.9, и я работал с ним в прошлом, но последние несколько лет использовал ZBrush и Blender.
Недавнее поглощение Pixologic Максоном кажется идеальным моментом для повторного открытия 3D-пальто. Я установил последнюю версию 2021 года.
Поскольку я уже много лет не был в 3DC, я освежаю свою память. Несколько вопросов:
1. Есть ли способ показать сцену или отдельный объект с неглаженными нормалями (гранеными, видимыми многоугольниками) ?
2. Есть ли способ сделать так, чтобы размер кисти оставался неизменным при увеличении масштаба? В ZBrush это происходит, когда вы отключаете динамический размер кисти.
3. Я не мог заставить работать клавиши цифровой клавиатуры (5 для переключения перспективы / орфографии и т. Д.). В чем может быть причина этого?
4. Были ли заменены живые глиняные кисти опцией "Удалить растяжение" в каждой щетке поверхностного типа?
Спасибо!
1),2),4) Видео . 5) Num Pad , все работает штатно . Вопрос 4) Теперь есть Relax , который может сгладить любые дефекты  поверхности , как и в Zbrush
This are the default shortcuts
Camera and Custom Navigation
NumPad 1    Bottom
NumPad 2    Front
NumPad 4    Left
NumPad 5    Toggle Perspective-Orthographic projection
NumPad 6    Right
NumPad 7    Top
NumPad 8    Back
Ctrl+Up Arrow           Add Camera Shortcut
Ctrl+Down Arrow      Delete Camera Shortcut
Ctrl+Left arrow         Switch to previous shortcut
Ctrl+Right arrow       Switch to next shortcut
  • Carlosan changed the title to 3DCoat questions
11 hours ago, Ctc_nick said:
Number 3: numpad is not activated! lg
Thanks, but in Blender the numeric keys work fine on the same system, only in 3DC none of the keys seem to work here.
1 hour ago, Carlosan said:
1 Its Flat shade view useful ?
2. May be you have brush locked ?
3. Try switching on/off BloqNum
4. Live Clay has been replaced by the powerful new brush system.
Please take a look
Thanks @Carlosan!
The non-smoothed normals turned out to be a shader setting. It works now.
Brush lock was indeed what I was searching for regarding the (non-)dynamic brush size, thanks.
Where can I find BloqNum? Do you mean keyboard NumLock or a 3DC option?
I'll check out the new brush engine.
A few more questions:
5. What would be the 3DC procedure comparable to multiresolution sculpting in ZBrush and Blender (retopo, then subdivide and sculpt on different polygon subdivision levels) ?
6. Is there a 3DC equivalent to ZBrush's Insert (Multi) Mesh brushes?
Thanks!
Added another question.
3DC dont have multires modifier as ZB or Blender, you can use Proxy Mode but it is not the same procedure
Sadly no, there is not any equivalente to IMM or Micromesh. This feature request was asked time ago, but still no luck.
v2021 license is multi OS, you dont need to buy additional licenses. Please contact sales@pilgway.com to get more details about it.
Carlosan
Yousung was awarded the badge 'Helpful' and 1 points.
On 4/5/2019 at 9:32 AM, Carlosan said:
Hi!
Try Sculpt Room> Import Tool
You can also save a Sculpt Object as a preset for the Import tool. That should do the trick for you.
To use the normal alignment like in ZB, tick on "On Brush" in the Tool Options panel.
And to make it a preset, RMB on the layer you want to save, then Export>Save to Meshes Panel.
Hope that helps.
You can do similar with the Import tool.
Thanks for your replies guys!
8. Can I activate an option somewhere to have the camera rotate around the last brushed point?
9. Can I reassign the Enter key (re-voxelize) to a different key?
Thanks!
Carlosan
It seems that we need to hear the answers from the developers for question 9.
Even if I reassign the shortcut key, the window does not appear,
I'm guessing it's probably hard-coded.
Thanks for your answers!
I've tried changing this in the 'options_hotkeys.xml' file:
But the new key assignment didn't work, and the Enter key didn't work anymore either, maybe because the new shortcut was already assigned?
I don't believe your question about repeating strokes was addressed, was it?
"1. Is there an equivalent to ZBrush's Repeat Last stroke ('1' key) ? I used that a lot in ZB to repeat the exact same stroke a few times when desired."
This is a feature I would kill to have in 3DCoat.  Any headway here in your 3DC rediscovery journey?
Thanks. The closest equivalent would be using a curve to guide the stroke, but that's more cumbersome than a 'repeat stroke' tool.
I'm still much enjoying my 3DC rediscovery journey, viewing lots of interesting video tutorials.
One new question:
Once you're creating a curve with the Curves tool, is it possible to change the outer end red sphere from which the curve will smoothly continue? In other words: how do I smoothly continue building a curve from the start sphere, in stead of the end sphere? I hope I'm clear enough. :blush:
Sorry, I don't know if the translator is translating properly.
Do you mean that you want to swap the start and end points of the curve?
if that's the case
1. Right-click on the curve.
2. Select 'Curve Operations - Reverse Curve Direction'
3. The direction of the curve is reversed.
1214071830_bandicam2022-01-1620-43-16-995.thumb.jpg.41d3d25fae432a803a781f82b7afe0ce.jpg
1554125540_bandicam2022-01-1620-42-59-780.thumb.jpg.6a789d35dc28006731e2fe96ecd35b4d.jpg
Thanks @Yousung!
I meant the Curves tool with the red spheres. In the example below I've started adding curve points from the bottom to the top, but the next point is always drawn from the last placed point. How do I indicate that I'd like to smoothly continue building the spline from the bottom point?
Right, that is the way to "repeat stroke" in 3DC, but you can't apply varying pressure to a stroke using that method (with pen tablet etc)
The other work around is to create a new sculpt layer, make your stroke on that layer, and then duplicate the sculpt layer once and many times to get the amplification of the stroke you just made.  I wish this could be done with one click like in zBrush.  Seems like such a small request - maybe it's a coding nightmare...I don't know.  But it's something that has been requested in the past and doesn't look like we'll get it.
Happy to see you enjoying your 3DC rediscovery mission!  Keep us posted!
Carlosan
oh that curve :D
I haven't used that curve much
It seems to work by setting the Edit mode from 'Extrude' to 'Move' and then adding a point in the middle.
2073936830_bandicam2022-01-1710-17-09-816.thumb.jpg.ca484d241eced526ec3a4ef2dcb275ee.jpg
To insert, when you hover the mouse over the curve and a green sphere appears, left-click.
There is a way to create and continue a new curve with 'New Curve', but this will produce slightly different results than working with a single curve.
https://3dcoat.com/dokuwiki/doku.php?id=general:sculpt_workspace:curves
Carlosan
Yousung was awarded the badge 'Great Support' and 1 points.
1323217459_bandicam2022-01-1816-39-17-009.thumb.jpg.63ef08118e5c76a6c0e25d7472b7bc51.jpg
This option can be activated in Modeling Room and Retopo Room.
You can use it by checking Sculpt Mesh in the upper Mesh menu.
If you want to switch to a Sculpt Mesh while working, press Unlink Sculpt Mesh.
If you want to see the poly model transparently like the video (if you want to see only the Sculpt mesh)
Just lower the Opacity value at the top.
Edited by Yousung
  • Thanks 2
Great, thanks! :good:
Trying out live subdivision, and after activating symmetry and extruding, the symmetry is not present in the subdivided result. How come?
And another question, sorry:
The Expand brush comes closest to the Inflate brush in Blender / ZBrush, or not? In that case, Control + brushing doesn't deflate. Is there a separate brush or mode for that?
I found that performing a Smooth All on a layer also deflates a little, but it'd be great if you could deflate on a brush level.
─ Edit: Control + Fill seems to work for deflating thin, low-polygon geometry. I would love to see Control + Expand offering a real deflate effect though.
Carlosan
1856418724_bandicam2022-01-1821-33-16-583copy.thumb.jpg.bb13ef2aceda53b42c4fca76e686ee8a.jpg
When you use Symmetry in Modeling Room, it appears to be working symmetrically in the viewport, but it is actually in a state before it was created.
It's because of Mesh - Virtual Mirror Mode, do Apply Symmetry or
You need to do Symmetry Copy from Polygroups.
  • 2 weeks later...
4 hours ago, Metin Seven said:
I just wanted to try the Radial Array, but I don't see anything change in my scene. Does it work in Voxel mode?
This question doesn't really matter anymore, as I've just discovered the Axial tool. Perhaps that's the successor to the Radial Array layer menu item?
And another question... :)
What's the easiest way to create a straightforward (non-radial) array / ordered number of copies of a layer?
And is it possible to get the result into the same layer in stead of getting tens of layer copies?
Thanks in advance!
