Carlosan Posted January 28, 2022 Report Share Posted January 28, 2022 Try Twist //added 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Metin Seven Posted January 29, 2022 Author Advanced Member Report Share Posted January 29, 2022 Thanks @Carlosan, very handy! I'm currently also experimenting with the more powerful 'Bend Volume' along a curve. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Metin Seven Posted January 31, 2022 Author Advanced Member Report Share Posted January 31, 2022 At around 16:50 in this video the creator activates Fill With Mesh Layer for a curve, then clicks on an item in the Splines panel to have the item follow the curve. But when I try that, the old Curves tool gets activated and clicking on a Spline panel item doesn't make it follow the new curve type. Can anyone help me out? Thanks! https://youtu.be/scWV6jtxeXY?t=1009 Quote Link to comment Share on other sites More sharing options...
Member Solution Евгений Posted January 31, 2022 Member Solution Report Share Posted January 31, 2022 This post was recognized by Carlosan! Евгений was awarded the badge 'Helpful' and 1 points. 2 hours ago, Metin Seven said: Примерно в 16:50 в этом видео создатель активирует заливку сетчатым слоем для кривой, затем нажимает на элемент на панели "Сплайны", чтобы элемент следовал за кривой. Но когда я пытаюсь это сделать, активируется старый инструмент "Кривые", и нажатие на элемент панели "Сплайн" не заставляет его следовать новому типу кривой. Кто-нибудь может мне помочь? Спасибо! https://youtu.be/scWV6jtxeXY?t=1009 Он использовал данный инструмент и он работает . А так же вы можете менять масштаб используя радиус кисти , сняв галочку блокировки . Rec 2022-02-01 01;18;42.mp4 2 Quote Link to comment Share on other sites More sharing options...
Advanced Member Metin Seven Posted February 1, 2022 Author Advanced Member Report Share Posted February 1, 2022 Many thanks, @Евгений! It works! Quote Link to comment Share on other sites More sharing options...
