[Solved] Not detecting edge loops
Ratchet
Carlosan
Yousung was awarded the badge 'Helpful' and 1 points.
It seems to be a sharp edge.
Objects imported from other tools often see this case.
To check if it is a sharp edge, you can check it with Show sharp edges in the drop menu (Simple Checker) at the top left.
Please try again after removing the sharp edge by following
732807361_bandicam2022-01-1112-15-47-626.thumb.jpg.cb6808253483dee8cf79d1821c10a4d5.jpg
1. Using 'Select'
2. 'edge' selection mode
3. Select all edges
4. Clear Sharp
Or if you want to perform Loop select while keeping sharp edges
Uncheck 'Stop edge loops at sharp'.
So 3D coat Instant Mesh produced sharp edges, because the low polty mesh was not imported from other software.
I'l have to recheck also 3D coat "Instant Mesh manual" and see if there is more optiosn to avoid sharp edges.
Thank you very much, i'll try.
  • Carlosan changed the title to [Solved] Not detecting edge loops
