Advanced Member Ratchet Posted January 10, 2022 Advanced Member Report Share Posted January 10, 2022 Loops are everywhere, why edge loops does not work on that retopology ? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 10, 2022 Report Share Posted January 10, 2022 Hi Testing .88 cant replicate that issue, sorry Quote Link to comment Share on other sites More sharing options...
Advanced Member Ratchet Posted January 10, 2022 Author Advanced Member Report Share Posted January 10, 2022 (edited) Hi Carlosan, You'll find 3D coat file download link, if you want to try. https://ufile.io/adruyj04 I opened again the file, on retopo mode same isssue, 3D coat unable to detect egde loops. Very strange, or has file been corrupted somewhere ? Edited January 10, 2022 by Ratchet Quote Link to comment Share on other sites More sharing options...
Advanced Member Yousung Posted January 11, 2022 Advanced Member Report Share Posted January 11, 2022 This post was recognized by Carlosan! Yousung was awarded the badge 'Helpful' and 1 points. It seems to be a sharp edge. Objects imported from other tools often see this case. To check if it is a sharp edge, you can check it with Show sharp edges in the drop menu (Simple Checker) at the top left. Please try again after removing the sharp edge by following 1. Using 'Select' 2. 'edge' selection mode 3. Select all edges 4. Clear Sharp /// Or if you want to perform Loop select while keeping sharp edges Uncheck 'Stop edge loops at sharp'. Quote Link to comment Share on other sites More sharing options...
Advanced Member Ratchet Posted January 11, 2022 Author Advanced Member Report Share Posted January 11, 2022 So 3D coat Instant Mesh produced sharp edges, because the low polty mesh was not imported from other software. I'l have to recheck also 3D coat "Instant Mesh manual" and see if there is more optiosn to avoid sharp edges. Thank you very much, i'll try. Quote Link to comment Share on other sites More sharing options...
Advanced Member Ratchet Posted January 11, 2022 Author Advanced Member Report Share Posted January 11, 2022 (edited) The bug is about InstantMesh retopo. Without symmetry InstantMesh creates only sharp edges, with symmetry InstantMesh does not create any sharp edges. 3D coat 2021.86 Edited January 11, 2022 by Ratchet Quote Link to comment Share on other sites More sharing options...
Advanced Member Ratchet Posted January 11, 2022 Author Advanced Member Report Share Posted January 11, 2022 (edited) I have a question, why Autopo produces a strange blue lines visualisation of polygons not really needed, when InstantMeshes produces simple and more clear polygons display ? Edited January 11, 2022 by Ratchet Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 14, 2022 Report Share Posted January 14, 2022 Blue edges are marked as hard edges, but there are not. It is a visual glitch. Quote Link to comment Share on other sites More sharing options...
