Member Sqwert Posted January 13, 2022 Member Report Share Posted January 13, 2022 (edited) Viewport locking does not work with 3 Space mouse compact 2022-01-13 19-13-36.mkv Edited January 13, 2022 by Sqwert Quote Link to comment Share on other sites More sharing options...
Member Sqwert Posted January 13, 2022 Author Member Report Share Posted January 13, 2022 Testing in 4.9x same result. Basic stuff as seen in free software like Blender... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 15, 2022 Report Share Posted January 15, 2022 On Preferences > 3D Mouse You can test switching onUse 3D-Connexion API from 3D-Coat 4.xx: Use older version of 3D-Connexion API. It is not recommended because in some cases it may lead to additional lags if you use wireless devices (mouse, pen, keyboard). But if the new API does not work for you - please use older one. 3DCoat takes all that settings from the Control panel of the 3D-Connexion device, so no need for many settings there. So press the device settings/menu button and edit the settings there. Pay attention, rotation around the vertical axis is in Advanced settings -> Navigation modes -> Lock horizon. Quote Link to comment Share on other sites More sharing options...
Member Sqwert Posted January 15, 2022 Author Member Report Share Posted January 15, 2022 (edited) My default setting was "use API from 4.xx", using this setting the views are not locked in Ortho Front/Back etc When I switch that setting off in 3D mouse menu, the view lock does work as intended. But after the switch, setting "reverse" in the Devices Advanced settings has no effect in 3Dcoat. That means my controls are always reversed making navigation impossible. It seems 3DCoat does not take this setting from the 3D connection device Edited January 15, 2022 by Sqwert Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 16, 2022 Report Share Posted January 16, 2022 I forwarded your issue to dev team, but please keep in contact with Andrew Shpagin to ask a possible solution. Thanks Quote Link to comment Share on other sites More sharing options...
Solution Andrew Shpagin Posted January 31, 2022 Solution Report Share Posted January 31, 2022 Looks like the driver issue because 3d-coat does not control viewport locking, it is controlled by 3dconnexion driver. Please update driver, uncheck 4.xx mode in preferences. Quote Link to comment Share on other sites More sharing options...
