Member zandernice Posted January 20, 2022 Member Report Share Posted January 20, 2022 In previous versions, there was a toggle checkbox for the tools to be negative or additive. Has that been removed? Do I have to now hold down the CNTRL button the whole time to make it subtractive? Or is the toggle hidden away somewhere? Quote Link to comment Share on other sites More sharing options...
Advanced Member sprayer Posted January 20, 2022 Advanced Member Report Share Posted January 20, 2022 Which tool are you using? Old tools have that checkbox for clay engine you may use negative settings in plane offset Quote Link to comment Share on other sites More sharing options...
Member zandernice Posted January 20, 2022 Author Member Report Share Posted January 20, 2022 12 hours ago, sprayer said: Which tool are you using? Old tools have that checkbox for clay engine you may use negative settings in plane offset huh... it doesn't have an affect on my model. Does it work for you? Quote Link to comment Share on other sites More sharing options...
Advanced Member Solution sprayer Posted January 20, 2022 Advanced Member Solution Report Share Posted January 20, 2022 This post was recognized by Carlosan! sprayer was awarded the badge 'Great Support' and 1 points. 2022-01-20 23-25-09.mp4 Yes it works for me. Make sure you are using latest build and try to reset tool, maybe you was change extrusion mode for example Quote Link to comment Share on other sites More sharing options...
Member zandernice Posted January 21, 2022 Author Member Report Share Posted January 21, 2022 ah.. ok. Thank you so much Quote Link to comment Share on other sites More sharing options...
