Advanced Member Ratchet Posted January 22, 2022 Advanced Member Report Share Posted January 22, 2022 Hello, I drag and drop an image on 3D coat and choose "Set as background" The image is always facing camera and always stays on backround, scale and move do nothing on the panel settings. Is this a bug ? And the gizmos and rectangle zone containing the background image are not visible. It's like a fixed background we can't remove. I tried to find an option to remove it on all menus and did not find anything or it is pretty well hidden Some little help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Advanced Member Solution Ratchet Posted January 22, 2022 Author Advanced Member Solution Report Share Posted January 22, 2022 (edited) Ok found it. Click on top righ camera icon -> Background -> Vertical Gradient Really hard to find while could have been lot more intuitive , for example on menu view -> clear background image Edited January 22, 2022 by Ratchet 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 22, 2022 Report Share Posted January 22, 2022 This is a little tricky: Edit > Customize UI - Left Paint Room tab can see a wrench icon, Edit the Current Room Settings - Press with LMB to show up Edit Menu Panel To keep changes* active after sessions Use Script for the menu must be active * all personal changes are stored at: C:\Users\username\Documents\3DCoat-2021\UserPrefs\Rooms\CustomRooms\Paint - Press Edit... a notepad popups letting us to edit: menu.cpp we like to add: Use vertical gradient to View Menu (i am adding it below Greyscale Panorama, change it to your location choice) - To know the command, press RMB and MMB at same time Greyscale Panorama command is: // cmd - based script: cmd("$GreyscaleLight"); // UI - based script, need to define the variable somewhere before: UI ui; ui("$GreyscaleLight"); - So on menu script i search for it, found over this section: void CreateViewMenu() { start_main_menu("VIEW"); menu_item("ShadingOptions");///ShadingOptions menu_separator(); menu_item("GreyscaleLight");///Greyscale Panorama - Now Press RMB and MMB at same time over > top righ camera icon -> Background -> Vertical Gradient, to know the command script line // cmd - based script: cmd("$GradientBackground"); // UI - based script, need to define the variable somewhere before: UI ui; ui("$GradientBackground"); - I added that line to the Menu View script void CreateViewMenu() { start_main_menu("VIEW"); menu_item("ShadingOptions");///ShadingOptions menu_separator(); menu_item("GradientBackground");///Clear Background Image menu_separator(); menu_item("GreyscaleLight");///Greyscale Panorama menu_item("VIEW_SHADED");///Smooth Shade menu_hotkey("5", 0, 0, 0);///5 - Press OK to close Edit the Room panel - that's all, hope i was clear Quote Link to comment Share on other sites More sharing options...
