Advanced Member Yousung Posted January 25, 2022 Advanced Member Report Share Posted January 25, 2022 (edited) I had a problem with FFD not working properly, but I couldn't reimplement it. Instead, I will test it a few times and write down improvements/bugs. Transform without gizmo cannot be used when 'Use Free Form' is checked. - If you use Transform without gizmo while holding the FFD Point, the pose area moves. - In other words, you have to select a point and move the gizmo directly. It is too difficult to select a Point of Free Form. - There is no way to add a Point when you need to select an additional Point. - There is only deselection (Ctrl) function. Symmetry is not moving properly. - Even if the FFD is modified to be symmetrical, it is not symmetrical. +edit 1) What is Free-Form? How to use it?. - Free Cube, Free Tube 2....I don't know what it is even when I click on it. Edited January 25, 2022 by Yousung 1 2 Quote Link to comment Share on other sites More sharing options...
Advanced Member jimhatama Posted January 26, 2022 Advanced Member Report Share Posted January 26, 2022 +1. That definently needs improvement Quote Link to comment Share on other sites More sharing options...
Advanced Member alvordr Posted January 29, 2022 Advanced Member Report Share Posted January 29, 2022 (edited) +1 I agree it needs work. I may be wrong, but maybe try pulling the vert on that box from the other side of the symmetry. I've noticed on occasion that 3D Coat wants to use only one side of symmetry to adjust both. Edited January 29, 2022 by alvordr Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 29, 2022 Reputable Contributor Report Share Posted January 29, 2022 On 1/25/2022 at 4:22 PM, Yousung said: I had a problem with FFD not working properly, but I couldn't reimplement it. Instead, I will test it a few times and write down improvements/bugs. Transform without gizmo cannot be used when 'Use Free Form' is checked. - If you use Transform without gizmo while holding the FFD Point, the pose area moves. - In other words, you have to select a point and move the gizmo directly. It is too difficult to select a Point of Free Form. - There is no way to add a Point when you need to select an additional Point. - There is only deselection (Ctrl) function. Symmetry is not moving properly. - Even if the FFD is modified to be symmetrical, it is not symmetrical. +edit 1) What is Free-Form? How to use it?. - Free Cube, Free Tube 2....I don't know what it is even when I click on it. When you check Free Form Lattice, it provides a Cube by default, but you are correct. The 2 options at the bottom are not functioning. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 2, 2022 Report Share Posted February 2, 2022 3DCoat-2021-96 - Fixed different problems related to transition of selection between the pose and freeze tools (especially in voxels). - If you are in voxels, coming in/out of Pose tool leads to voxelization even if the source tool is surface-based. This is done to avoid possible pose glitches. There is no way to add a Point when you need to select an additional Point. Press shift + LMB to select more points Quote Link to comment Share on other sites More sharing options...
Advanced Member Yousung Posted February 2, 2022 Author Advanced Member Report Share Posted February 2, 2022 nothing has been resolved.. - 'Transform without gizmo' is still not available during FFD. It is very inconvenient because it seems to be using the V4 version of Gizmo.During FFD, make sure to only operate on the FFD control point. - Symmetry option in FFD still behaves strangely. It doesn't work symmetrically and even transforms the opposite of the point. - It is possible in Brush mode of E-Pannel, but you cannot use Shift+LMB in 'Lasso'. When I try to do it the FFD turns gray and I can't drag it. I don't want to select every little control point... It's too inconvenient. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 3, 2022 Report Share Posted February 3, 2022 1 Quote Link to comment Share on other sites More sharing options...
