Member Just a user Posted January 26 Member Report Share Posted January 26 1. i have done sculpting 2. im pressing RMB on my surface and choose AUTOPO 3. i use this settings because i want a high poly mesh to export from 3dcoat 4. after calculation there is not polymesh in the retopo room How can i make this work? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 26 Report Share Posted January 26 Try lower Polycount, 10000 as example or Test if its working using any other basic model as default sphere For very highpoly models use Retopo via decimation or Instant Meshes (manual) Quote Link to comment Share on other sites More sharing options...
Member Just a user Posted January 26 Author Member Report Share Posted January 26 9 minutes ago, Carlosan said: Try lower Polycount, 10000 as example or Test if its working using any other basic model as default sphere For very highpoly models use Retopo via decimation or Instant Meshes (manual) Thank you i will try this. I have another question, I import a low poly model with uv into a surface. i sculpt that surface on high density. Now i want to bake the normal of this version to the original one which i have in FBX How to do that? all tutorials in youtube show how to retopo and then bake, not using surface and external FBX thank you Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 26 Report Share Posted January 26 Please check this workflow, Hope it help 1 Quote Link to comment Share on other sites More sharing options...
Member Just a user Posted January 26 Author Member Report Share Posted January 26 1 hour ago, Carlosan said: Please check this workflow, Hope it help Thanks I have seen the video but it did not explain how to import a model -> sculpt it -> and baked on the imported one Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 26 Reputable Contributor Report Share Posted January 26 This post was recognized by Carlosan! AbnRanger was awarded the badge 'Helpful' and 1 points. 9 minutes ago, Just a user said: Thanks I have seen the video but it did not explain how to import a model -> sculpt it -> and baked on the imported one There are other videos that show this, but this is a good example of importing a model made in another app, going through this process and exporting back to the host app. Quote Link to comment Share on other sites More sharing options...
Member Just a user Posted January 26 Author Member Report Share Posted January 26 Just now, AbnRanger said: There are other videos that show this, but this is a good example of importing a model made in another app, going through this process and exporting back to the host app. Thanks ! I have seen this one before, but the feature does not work for me (model appear for a split sec and then nothing on screen, tried press enter, tried to scale, nothing workd, 0 geometry), and he didn't tried to bake anything Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 26 Reputable Contributor Report Share Posted January 26 This post was recognized by Carlosan! AbnRanger was awarded the badge 'Great Support' and 1 points. 3 minutes ago, Just a user said: Thanks ! I have seen this one before, but the feature does not work for me (model appear for a split sec and then nothing on screen, tried press enter, tried to scale, nothing workd, 0 geometry), and he didn't tried to bake anything It goes through the process over the course of the series of videos, not just this one. In the Retopo Room, you can click on the IMPORT tool in the COMMANDS section or the MESH menu > IMPORT. Hit ENTER to commit it to a layer. In the Sculpt Workspace, you can go to the GEOMETRY menu > choose RETOPO MESH to SCULPT MESH and enable CONFORM RETOPO MESH, so that changes made to your High Poly are applied to the Low Poly Retopo Mesh, simultaneously. When done sculpting, you are ready to bake 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 26 Reputable Contributor Report Share Posted January 26 1 Quote Link to comment Share on other sites More sharing options...
Member Just a user Posted January 26 Author Member Report Share Posted January 26 6 minutes ago, AbnRanger said: Thank you ! amazing help I have seen this tutorial now, but i dont understand how do i start, in which room, and what to do with my low poly FBX, and how to get to where he is. And how to bake in the end ? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 27 Report Share Posted January 27 As AbnRanger said: Go to Retopo Room, Mesh Menu > Import Switch to sculpt Room, Geometry Menu > Retopo Mesh To Sculpt Mesh to get object from retopo Room This video show the steps: Quote Link to comment Share on other sites More sharing options...
Member Just a user Posted January 27 Author Member Report Share Posted January 27 @Carlosan @AbnRanger thanks guys But i should have done that before i started. and i will next time. i have already finished with the sculpting process, Now I have 2 fbx, one low and one high, hot to bake high to low ? ty Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 27 Report Share Posted January 27 Bake Menu 3DC upon importing into the sculpt room does not automatically create a low polygon retopo mesh for baking. You either import one, autopo or create a low polygon retopo mesh by hand in the retopo room. Once you have the retopo mesh completed in the retopo room, you create the uv seams. Then you unwrapped the model to create the uv set islands. Next you choose the various baking methods. Your model will be baked to the paint room for texturing. Here is a video series, that will help you understand 3DC not only the baking and texturing part. For now though start with video number 14... This is about autopo. The next is manual retopo and he goes all the way through to baking, texturing and exporting. He does not cover importing of retopo meshes but I give you a tip about it at the bottom of this post. The author here does not import the model but sculpts it in the sculpt room but the rest applies to you. Over time you will learn what method of importing your model works for the current model you are working on. Example of one Workflow: It is just an example that is all, as I said there are several methods. I have a hard surface high polygon model created in Blender and plus have the low polygon model of the same model created in Blender. I would import the high polygon model into surface mode, not voxel mode. Not explaining here about surface mode or the reason of using it in this example. Next I would import the low polygon model into the retopo room for my retopo mesh, then create my uv seams and uv set. Bake to the paint room to create the normal map details from the high polygon model in the sculpt room. Texture in the paint room and export. Source... 1 Quote Link to comment Share on other sites More sharing options...
Member Just a user Posted January 27 Author Member Report Share Posted January 27 Quote Example of one Workflow: It is just an example that is all, as I said there are several methods. I have a hard surface high polygon model created in Blender and plus have the low polygon model of the same model created in Blender. I would import the high polygon model into surface mode, not voxel mode. Not explaining here about surface mode or the reason of using it in this example. Next I would import the low polygon model into the retopo room for my retopo mesh, then create my uv seams and uv set. Bake to the paint room to create the normal map details from the high polygon model in the sculpt room. Texture in the paint room and export. Source... Thank you ! this is exactly what i was trying to understand in addition to the previous videos Will try that soon Quote Link to comment Share on other sites More sharing options...
Member Just a user Posted January 28 Author Member Report Share Posted January 28 On 1/27/2022 at 6:06 PM, Carlosan said: Bake Menu 3DC upon importing into the sculpt room does not automatically create a low polygon retopo mesh for baking. You either import one, autopo or create a low polygon retopo mesh by hand in the retopo room. Once you have the retopo mesh completed in the retopo room, you create the uv seams. Then you unwrapped the model to create the uv set islands. Next you choose the various baking methods. Your model will be baked to the paint room for texturing. Here is a video series, that will help you understand 3DC not only the baking and texturing part. For now though start with video number 14... This is about autopo. The next is manual retopo and he goes all the way through to baking, texturing and exporting. He does not cover importing of retopo meshes but I give you a tip about it at the bottom of this post. The author here does not import the model but sculpts it in the sculpt room but the rest applies to you. Over time you will learn what method of importing your model works for the current model you are working on. Example of one Workflow: It is just an example that is all, as I said there are several methods. I have a hard surface high polygon model created in Blender and plus have the low polygon model of the same model created in Blender. I would import the high polygon model into surface mode, not voxel mode. Not explaining here about surface mode or the reason of using it in this example. Next I would import the low polygon model into the retopo room for my retopo mesh, then create my uv seams and uv set. Bake to the paint room to create the normal map details from the high polygon model in the sculpt room. Texture in the paint room and export. Source... I tried to do this, but the shell (outer) in inserting inside in some areas, while the most is pulled outside. is there a way to import custom mesh ? or fix the shell manually? Thank you ! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 28 Report Share Posted January 28 If your model is very tiny, there is not physic geometry space to move shell limits. 1 Quote Link to comment Share on other sites More sharing options...
Member Just a user Posted January 30 Author Member Report Share Posted January 30 On 1/29/2022 at 1:36 AM, Carlosan said: If your model is very tiny, there is not physic geometry space to move shell limits. i will check that Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 7 Reputable Contributor Report Share Posted February 7 This post was recognized by Carlosan! AbnRanger was awarded the badge 'Helpful' and 1 points. On 1/28/2022 at 10:24 PM, Just a user said: I tried to do this, but the shell (outer) in inserting inside in some areas, while the most is pulled outside. is there a way to import custom mesh ? or fix the shell manually? Thank you ! I believe that Blender Applink series goes through the use of the Bake Settings Dialog, and you can use a brush to tweak spots where it's not extruding enough, although the rest of the mesh is. By default, you can just use your brush to pull vertices along the normals...so on the inner cage, the normals are pointing inward. On the outer cage, they are pointing outward. Holding CTRL will invert this action on the fly. 1 Quote Link to comment Share on other sites More sharing options...
Member Just a user Posted February 8 Author Member Report Share Posted February 8 On 2/7/2022 at 5:23 PM, AbnRanger said: I believe that Blender Applink series goes through the use of the Bake Settings Dialog, and you can use a brush to tweak spots where it's not extruding enough, although the rest of the mesh is. By default, you can just use your brush to pull vertices along the normals...so on the inner cage, the normals are pointing inward. On the outer cage, they are pointing outward. Holding CTRL will invert this action on the fly. Thanks, I see the brush can only pull / push on normal direction without direct control on the cage, but in this case some of them are getting into each other, and i need manual control Quote Link to comment Share on other sites More sharing options...
Advanced Member kenmo Posted February 9 Advanced Member Report Share Posted February 9 3D Coat is an outstanding app BUT it's auto retopo is light years behind Blender, Quad Remesher and Instant Meshes when it comes to speed and ease of use. Why has there been real no improvements in auto retopo in the last several years? What takes Quad Remesher about a minute to retopo takes 3DC a couple of hours. Sorry, but this is totally unacceptable. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 9 Reputable Contributor Report Share Posted February 9 4 hours ago, kenmo said: 3D Coat is an outstanding app BUT it's auto retopo is light years behind Blender, Quad Remesher and Instant Meshes when it comes to speed and ease of use. Why has there been real no improvements in auto retopo in the last several years? What takes Quad Remesher about a minute to retopo takes 3DC a couple of hours. Sorry, but this is totally unacceptable. I don't find this to be the case whenever I use it. The only time it would take hours is if it is really struggling with a very thin object or the user is trying to make it generate a mesh that is way too low...like 1500 polygons, when it actually needs 15,000. It is not a Game-Ready Mesh Generator. It generates (largely) evenly spaced quads. Test it on some splash screen models and see if you still have the same kinds of problems. There is also InstantMeshes, as an option in 3DCoat. Andrew just did a lot of work, improving Auto-Retopo, in the last several builds. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 9 Reputable Contributor Report Share Posted February 9 This post was recognized by Carlosan! AbnRanger was awarded the badge 'Helpful' and 1 points. 22 hours ago, Just a user said: Thanks, I see the brush can only pull / push on normal direction without direct control on the cage, but in this case some of them are getting into each other, and i need manual control There is no manual control, such as vertex selection > Transform Tool. There is just a global extrusion and localized brush adjustments. There are options in the Bake Settings dialog, to RELAX, and you can always reduce your brush size and strength, to push/pull individual vertices, if needed. Quote Link to comment Share on other sites More sharing options...
