Advanced Member Metin Seven Posted January 29, 2022 Advanced Member Share Posted January 29, 2022 (edited) Hi, When I drag the Pose tool line gizmo, hold down the pen tip / LMB, and additionally press Spacebar to move the line, the Quick Access menu pops up. I've tried with both Wacom pen tip and left mouse-button, same issue. I've also tried switching from Wintab to Windows Ink in the Preferences, but the problem persists. When I reassign the Quick Access menu to a different keyboard shortcut, the Quick Access menu doesn't pop up anymore, but dragging the line with Spacebar pressed just doesn't move the line, as if Space is not triggered / recognized by the Pose tool. I'm using 3DC 2021.95 on Windows 10, latest Wacom driver (installed on January 29th). Any help (or possible bug fix) would be much appreciated, thanks in advance. Edited January 29, 2022 by Metin Seven Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 29, 2022 Reputable Contributor Share Posted January 29, 2022 This post was recognized by Carlosan! AbnRanger was awarded the badge 'Helpful' and 1 points. 53 minutes ago, Metin Seven said: Hi, When I drag the Pose tool line gizmo, hold down the pen tip / LMB, and additionally press Spacebar to move the line, the Quick Access menu pops up. I've tried with both Wacom pen tip and left mouse-button, same issue. I've also tried switching from Wintab to Windows Ink in the Preferences, but the problem persists. When I reassign the Quick Access menu to a different keyboard shortcut, the Quick Access menu doesn't pop up anymore, but dragging the line with Spacebar pressed just doesn't move the line, as if Space is not triggered / recognized by the Pose tool. I'm using 3DC 2021.95 on Windows 10, latest Wacom driver (installed on January 29th). Any help (or possible bug fix) would be much appreciated, thanks in advance. I don't think the line selection mode in the Pose tool was intended to utilize the SPACE bar this way. When using shape or spline draw modes from the E-panel, the SPACE bar can be invoked like it is in Photoshop. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Metin Seven Posted January 29, 2022 Author Advanced Member Share Posted January 29, 2022 (edited) Thanks @AbnRanger. I'll keep that in mind. @Silas Merlin I thought you did manage to move the Pose line gizmo while holding down Space, or did you mean moving shapes in the Pose tool's Paint mode? Edited January 29, 2022 by Metin Seven Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted January 30, 2022 Reputable Contributor Share Posted January 30, 2022 spacebar does move pose selection with a number entered in the box, on my side 1 Quote Link to comment Share on other sites More sharing options...
Solution Andrew Shpagin Posted January 30, 2022 Solution Share Posted January 30, 2022 Space does not influence when you drag pose selection. But it allows you to enter numerical values if you drag gizmo. So all seems correct there. 1 Quote Link to comment Share on other sites More sharing options...
