Member tcwik Posted February 9, 2022 Member Report Share Posted February 9, 2022 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 9, 2022 Report Share Posted February 9, 2022 Hope this help On 8/17/2021 at 4:28 AM, Yousung said: If the middle part of the model does not repeat, check the following 1. Is the object named as follows? - Top_@@@ - Middle_@@@ - Bottom_@@@ 2. Is the connection part of the object 'Open edge'? - Spline guidelines say that the top-middle-bottom part should be an open edge 3. This is just in case, but have you actually registered and tested it instead of a preview in the creation stage? - It does not seem to be repeated in the preview, but if you follow steps 1 and 2 properly, the result will be repeated middle-parts normally. 1 Quote Link to comment Share on other sites More sharing options...
Member tcwik Posted February 9, 2022 Author Member Report Share Posted February 9, 2022 This is Holy Grail, should be a tutorial for this action in 3d coat YouTube side official !.. BIG Thank You for the quick rep! Quote Link to comment Share on other sites More sharing options...
