Merging and AutoTopo
Lucas aka Zoisw
  • New Member
Hey everyone.
Recently I started to learn 3D Coat and I was trying to practice with some tutorials, I started with two mannequins and put them in my desired position, when I tried to "Merge Sub-Tree (No Booleans)" one of my mannequins it merges with the other, has 4 arms and 4 legs, and if I merge the other one's sub tree happens the same. How can I avoid that?
Consequentely, when I try to AUTOPO > Instant Mesh (auto) it only meshes the upper body of my mannequin. Also need help in that part!
Hi
Why do you need to merge 2 Sculpt layers with different individual models?
  • New Member
Hey
I don't know how to explain it but in the tutorial there's a step where you merge the sub-tree so you dont have that many objects I guess, and he did that to each one.
When I do that to one of my mannequins this happens!
As i see, there is one model and the instance.
Try making Layer copy on original mannequin first
and make 1 retopo by model, it will help (you can merge retopo models later)
