Advanced Member Vexod14 Posted February 23 Advanced Member Report Share Posted February 23 (edited) Hello ! I'd like to have the possibility to control Alpha through any layer I want. Currently, if you deactivate Layer 0, then the "alpha" will rely on what's painted above, so you need to clamp your paint zones to either a frozen area or use the lock transparency otpion on every layer...which is not practical. Alpha could be controlled using one or more dedicated layers which would act as a global alpha channel for everyone and get used in export constructor. This blend mode could be stored along all the others, which will be natural to access Thanks ! Edited February 23 by Vexod14 1 Quote Link to comment Share on other sites More sharing options...
