Member raincole Posted February 28, 2022 Member Report Share Posted February 28, 2022 I checked this post: But it didn't say how exactly to import unzipped Megascan materials. My download folder looks like this: I tried to set "Additional Quixel Folder", but it didn't work either. I've set it to "Megacan", "Megascan/Downloaded", "Megascan/Downloaded/surface". None of these worked. Please help me! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 2, 2022 Report Share Posted March 2, 2022 Hi Import megascan is not working as expected, right is not working as zip. You need to attach it using this command: Add existing materials folder Only need to select one map inside the folder. this popup let to select filename extensions * Avoid pic selection nomenclature empty and duplicate textures (color and albedo) I was testing a folder exported from quixel, cant found issues This is the complete list of aliases (at the end of the filename) used to recognize the texture usage: Bump: _DEPTH, _BUMP, _DEEP, _DISPL, _DISP, _DISPLACEMENT, _D Normalmap: _NMAP, _NM, _NORMAL, _NORMALMAP, _NORM, _NORMALS, _N Color: _COLOR, _CLR, _DIFFUSE, _ALBEDO, _CL, _RGB, _DIF, _C Gloss: _SPEC, _GLOSS, _GLOSNESS, _GLOSINESS, _GLOSSNESS, _GLOSSINESS Roughness: _ROUGH, _ROUGHNESS, _R Clip mask: _MASK, _MSK, _MS, _CLIP, _ALPHA Metallness: _MET, _METAL, _METALL, _METALLICITY, _METALICITY, _METALNESS, _METALLNESS, _MT, _ME, _METL Ignored: _PREVIEW, _PREV, _TMB, _THUMBNAIL, _PRV, _AO, OCCLUSION The any of . - ~ may be used instead of the sign. need to add * to beginning of every nomenclature example: Color: *_COLOR, *_CLR, _DIFFUSE, *_ALBEDO, *_CL, _RGB, _DIF, *_C Quote Link to comment Share on other sites More sharing options...
