Carlosan Posted April 1 Report Share Posted April 1 Quickstart You can manage 3DСoat features with help of scripting. The start is quite easy. Just use: Scripts Menu > Create your Script. Create new Core API script. - Scripting is a series of commands that are able to be executed without the need for compiling. When we select a tool or execute a function we are executing a command already included in the program. Creating a script allows us to combine these commands to automatically execute a series of steps that speed up our work. - Core API (Application Programming Interface) is not just the scripting, the code you write runs at full speed of compiled C++. The clang-cl compiler used for the compiling. It is the powerful method to extend the 3DCoat's functionality. You may automate the job or add principally new tools. Scripting 3DCoat Scripting 3DCoat uses AngelScript, which is a C++ like language. The script is a text file with commands* that are executed in personal order. That command can be known by recording it in memory by pressing over the function RMB+MMB at the same time. Opening a notepad and pasting it we will obtain the text of the corresponding command. It is helpful to view and edit it in Notepad++ (choose “C” syntax). Then run script via file menu “Scripts / Run Script. Core API Core API introduction The Core API is the powerful method to extend the 3DCoat's functionality. You may automate the job or add principally new tools. This is not just the scripting, the code you write runs at full speed of compiled C++. The clang-cl compiler used for the compiling. Core API script is a compliable C++17 program, so it works on the full native C++ speed. This is far more than just a script; you may make even time-critical and multithreaded tasks and customize the 3DCoat in-depth, creating principally new functionality and tools. But the whole process is completely transparent for you. You don't need to configure anything or manage complex project configurations. 3DCoat will lead you through the whole process with a simple wizard. ----------------------------------------------------------------------- The start is quite easy. Just use Scripts->Create new Core API script Then choose the template, choose path for your project. If the Visual studio (or Visual Studio Code) installed it will start with your new file. Each example is well documented, used relatively simple syntax, so it is easy to understand from easy to complex. Examples Looking the Examples is the best way to understand the API. Use Scripts->Create new Core API script to experiment with that examples. Quote Link to comment Share on other sites More sharing options...
