Member Mekky Posted April 9, 2022 Member Report Share Posted April 9, 2022 This post was recognized by Carlosan! Mekky was awarded the badge 'Great Support' and 1 points. No matter the settings I use, the renders all end up empty. Anyone know how to fix this? I am usng the 3dCoat Hardware render Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 13, 2022 Report Share Posted April 13, 2022 Hi Could you please test latest version ? Thanks Quote Link to comment Share on other sites More sharing options...
Member Mekky Posted April 18, 2022 Author Member Report Share Posted April 18, 2022 On 4/13/2022 at 6:00 PM, Carlosan said: Hi Could you please test latest version ? Thanks How can I know if the installation succeeded? Where do I find the current installed version number? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 18, 2022 Report Share Posted April 18, 2022 Check the Menu at Upper Left Or Help > About Quote Link to comment Share on other sites More sharing options...
Member Mekky Posted June 14, 2022 Author Member Report Share Posted June 14, 2022 This post was recognized by Carlosan! Mekky was awarded the badge 'Helpful' and 1 points. It's been a while. I installed 2022.29 it still produces a 0kb mp4 file when I render a turntable. Made with the default render settings All the software on my computer is up-to-date and still running W10 64bit except that I now have an RTX 3080 installed instead of a GTX 1070ti 1 Quote Link to comment Share on other sites More sharing options...
Member Mekky Posted June 14, 2022 Author Member Report Share Posted June 14, 2022 Just installed the 2022.31 beta and this still has the same issue 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 20, 2022 Report Share Posted June 20, 2022 Hi Could you please try latest version ? Thx 3DCoat-2022-32 Mon Jun 20 00:10:35 2022 - Render turnables improved essentially - better quality, convenient options set, possibility to render turnables with high resolution even if screen resolution is lower. Quote Link to comment Share on other sites More sharing options...
Member Mekky Posted June 22, 2022 Author Member Report Share Posted June 22, 2022 On 6/20/2022 at 3:42 PM, Carlosan said: Hi Could you please try latest version ? Thx 3DCoat-2022-32 Mon Jun 20 00:10:35 2022 - Render turnables improved essentially - better quality, convenient options set, possibility to render turnables with high resolution even if screen resolution is lower. Installed it but no results Still creates a 0-kb file. Only settings I changed this time is the number of frames. From 360 to 180 so I wouldn't have to wait that long. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 22, 2022 Report Share Posted June 22, 2022 it is working from my side, I cant replicate sorry. Try using this settings please Quote Link to comment Share on other sites More sharing options...
Member Mekky Posted June 22, 2022 Author Member Report Share Posted June 22, 2022 I'm not sure what happened but when I increase the [Rays Per Frame] and [Frames To Render] incrementally by doubling the number, it works I started from 1 ray and 4 frames as you told me to and went all the way up to 1600 rays and 265 frames. Thanks for the help! 1 Quote Link to comment Share on other sites More sharing options...
Member Mekky Posted July 4, 2022 Author Member Report Share Posted July 4, 2022 (edited) Okay so... The issue with making video's is resolved BUT I would also like to create a sequence of images for use in Premiere or something. You can probably see this coming but now that it creates a video, it no longer creates a sequence of images. Even with the settings we tried up here ^^^^ [EDIT 1] whoops forgot to mention that I've tried multiple versions. I started with 3DCoat-2022-32 and tried all the updates untill 3DCoat-2022-35 [EDIT 2] Downgraded to 2022.29 and the image sequence works as expected, but the video is back to 0kb Edited July 4, 2022 by Mekky 1 Quote Link to comment Share on other sites More sharing options...
